Author Topic: Displaying catver info in Mamewah  (Read 1548 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« on: September 30, 2004, 08:30:12 am »
I am using mamewah 1.51 and have my layout setup to show catver info.  I have placed my catver file in my mame folder and I have the emulator ini file pointing properly to my catver location.  For whatever reason I can not get my catver info to display in mamewah.
Anyone have any clues as to why it won't work?
Re:Displaying catver info in Mamewah
« Reply #1 on: September 30, 2004, 10:36:13 am »
Couple of things:
1) Did you enter the whole path including the filename?  eg:
catver_ini_file                           c:\mame\catver.ini
2) Did you refresh the main list since you entered the catver filename?
sac01
  • Last login:February 27, 2016, 08:15:22 am
« Reply #2 on: September 30, 2004, 07:14:35 pm »
I thought this was just me...Now i feel better
I have the same problem... i have the path set to my catver.ini correctly, i edited my skin to add the catver info window.
 Then i've refreshed the game list...still nothing showing in the catver.ini section :(
sac
Chester
  • Last login:December 23, 2004, 07:51:02 pm
  • Do I look like I know what you think I'm doing?
« Reply #3 on: September 30, 2004, 08:48:04 pm »
Ditto here as well. What version of MAME is eveyone else running, if that matters in any way? I'm running NoNameMAME. I'd love to get this working as well.
Popcorrin
« Reply #4 on: October 01, 2004, 11:13:24 pm »
Refreshing the game list did the trick.  Thanks Minwah
tshizzle.com
  • Last login:January 07, 2005, 01:38:05 pm
    • tshizzle.com
« Reply #5 on: October 23, 2004, 02:02:15 am »
me three .... catver is definetly there, rom folder vs dat file is there, and path to dat file is set (created from the command line like ur instructions)
When i refresh main list - no problems.  Go to a custom list, hit generate list, I get no options and it makes a list of every game (does filter out clones, but nothing else)
« Reply #6 on: October 23, 2004, 12:39:24 pm »
This is a bug - should be fixed next time...
I am not sure about the catver problem - it definately works OK for me.  Just make sure you have the main list selected when generating the list ('Generate List' not 'Generate Filtered List...').
