Author Topic: Mame32 button mapping issue....???  (Read 1394 times)
GCS
  • Last login:August 09, 2021, 01:15:28 pm
« on: September 16, 2004, 12:11:00 pm »
Hey folks I've got something that seems to be occuring A LOT more now than before.
In many games when you bring up the configuration menu to assign buttons for each action it will not map them correctly.
Example (Track & Field, Popeye and others):
Map Player 1 Button 1 -- when you select that button and then press the corresponding button on the CP it registers as LeftCtrlRightCtrl.  No matter what I do it always does this.
I have checked my mapping in the IPAC software and it shows up there just fine.  It will also do this if I attach the keyboard and try to press the actual key on the keyboard and NOT the button on the CP.
I am having this problem on 2 different machines (one has an IPAC4 and the other a Minipac).  I should also mention that it does this on ANY button tha is not a letter or number (ie X, Y, Z etc map fine but any that is supposed to be LeftCtrl, LeftAlt, LeftShift, Right..., Right... etc.) always screws up.
Any thoughts??
Greg
_Iz-
  • Last login:May 19, 2026, 09:24:45 pm
  • Time to coin up!
Re:Mame32 button mapping issue....???
« Reply #1 on: September 19, 2004, 03:32:14 pm »
Any thoughts??
Greg
Don't pause the game when you map controls.
