Author Topic: Here's my marquee- suggestions?  (Read 2252 times)
El Bucle
  • Last login:February 19, 2005, 11:28:44 pm
  • And a llama I shall remain. . .
« on: September 11, 2004, 04:20:24 pm »
I've been working on it for a while, and for the most part I'm satisfied, but I'm open to any suggestions.
First off, a few problems: Will the huge white laser jet stream thing be too distracting with a light behind it? I was thinking about just layering some extra paper in that certain area if it turns out it's too bright.  Seems like it'll work, but I'm a mere llama, what do I know?  Also, when I started playing around with photoshop I had the image's resolution set at the standard 72.  Should I do something about it?  Is there any way to convert it without redoing the image?  It shouldn't take more than 30 minutes to redo, so that's ok if I have to.
I'm currently working on a space-themed cp overlay to match. . . hopefully I'll have that posted soon.  ;D
Edit: Woohoo, it worked!
« Last Edit: September 11, 2004, 04:33:22 pm by El Bucle »
dbaleckaitis
  • Last login:November 11, 2014, 09:54:22 pm
  • I Love you MAME
Re:Here's my marquee- suggestions?
« Reply #1 on: September 11, 2004, 05:13:26 pm »
Use purple, and switch to a blacklight.
Or make a gradiant from white to purple.
If you look at mine, on Oscar's page Dan B. fighting marquee you will see I used purple and with a black light it looks great.  Give an almost 3D feel to it.
Dan
Robopede
  • Last login:October 18, 2004, 11:24:52 pm
  • 80's rule!
« Reply #2 on: September 11, 2004, 10:04:40 pm »
Maybe make the rainbow colors in the word "ARCADE" transition gradually? That would create a slightly different look, but maybe not what you're going for...
Look inside and you will see
The dream is my reality
El Bucle
« Reply #3 on: September 11, 2004, 10:25:17 pm »
Thanks for the replies.  I don't think purple would really work with the color scheme because I'm going for the whole red-blue-green-yellow thing.  It's a 4-player cab and there'll be one color for each player.
I'll try the fade effect and put it up here. . .
hunky_artist
  • Last login:April 15, 2006, 06:39:21 pm
    • www.pennylanepictures.com
« Reply #4 on: September 12, 2004, 08:57:09 am »
I really like that  ;D
(my art website) :)
itismejs
  • Last login:February 29, 2012, 05:25:43 pm
« Reply #5 on: September 12, 2004, 12:01:36 pm »
That galaga ship better be vectorized......
