Author Topic: Hantarex Monitor shaking?  (Read 3218 times)
LsLSpamMatt
  • Last login:December 25, 2019, 09:45:46 pm
  • Yeah, I drink Diet Coke
« on: August 18, 2004, 08:59:43 am »
Hey again informative/knowledgeable types,
I've got a not obviously identifiable Hantarex monitor.
I was playing it this morning and the picture started shaking
from side to side rapidly.
It wasn't horrible, but quite noticeable.
Is there a term for this shaking, and hopefully a fix?
Any tips on identifying this 19" Hantarex would
also be great.
Thanks,
Matt
Ken Layton
  • Guru
  • Technician
Re:Hantarex Monitor shaking?
« Reply #1 on: August 18, 2004, 10:35:45 am »
Post a small file size picture of the monitor's main circuit board.
LsLSpamMatt
« Reply #2 on: August 18, 2004, 10:59:36 am »
Ken,
This is something I will do once I find a way to make my
digicam work.  This will be accomplished today.
Matt
LsLSpamMatt
« Reply #3 on: August 18, 2004, 07:21:22 pm »
Ken,
I wanted to keep the small print legible, so I'll just link to them.
Hope they are sufficient.
Matt
Each one is about 160kb
http://www.geocities.com/spammatt/board.jpg
http://www.geocities.com/spammatt/board2.jpg
http://www.geocities.com/spammatt/board1.jpg
Ken Layton
  • Guru
  • Technician
« Reply #4 on: August 19, 2004, 12:35:59 am »
You have a Hantarex model MTC 900/E. I have written a repair guide in Microsoft Works format. You definitely need a capkit for this monitor. This monitor needs a lot of capacitors and that is your shaking problem. I made a list of caps and it uses 29 caps! Zanen Electronics and Bob Roberts has kits for this model. My advise would be get a capkit installed very soon. If you leave it this way it will take out the vertical deflection IC3 (TDA2653A) and resistor R56.
LsLSpamMatt
« Reply #5 on: August 19, 2004, 10:31:32 pm »
Ken,
Ah, the 900/E.  I actually stumbled upon a manual in PDF format earlier, and was hoping that was the model.  Thanks for the identification.
As far as the cap replacement kit goes, is there a way to receive a copy of your repair guide?
Also, is the process of installing a cap kit complicated?  I am not a very effective solderer, and have been spooked into total fear of the discharge process.
I may go ahead and order the cap kit soon.
Thanks,
Matt
