Author Topic: WG-D9200 Connection Question....  (Read 1715 times)
squizz
  • Last login:May 20, 2005, 05:32:41 am
« on: August 09, 2004, 08:52:39 am »
 Okey i have the Wg-D9200 installed and are just installing the arcadeVGA card into the PC and was wondering about one question...
  I have a Jpac installed and noticed the plug goes from the Jpac to the pc , now on the WG-D9200 monitor the Cables go to the CGA and EGA connector for the SF2 Gameboard i have installed....
 So do i leave the connector on the EGA, CGA connector or will i have to connet to the VGA slot for the pc For emulating mame with the 15/25/31hz mode's !  ?
  Can someoen with the same set up let me know please..
Thank you
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
Re:WG-D9200 Connection Question....
« Reply #1 on: August 17, 2004, 02:06:41 am »
so you have a dual setup a game and mame? if so this is how i had to do my setup. when running the pcb i had to have the vga cable plugged in but also the cga/ega plug in with the ovbious that the connector was setup on the cga/ega to play the pcb. when i wanted to play mame i would simply unhook the cga/ega connector from the monitor and change it to the vga mode. for some reason my video would jump playing the pcb if i didnt have the vga cable hooked up. dont knwo why. but it wouldnt work if i had both hooked up when i wanted to use mame....hope this helps
