Author Topic: Sorting Roms  (Read 1288 times)
Trimoor
  • Last login:November 18, 2006, 09:01:46 pm
  • I like shooting out of helicopters.
    • Trimoor
Sorting Roms
« on: August 04, 2004, 02:05:13 pm »
How can I sort through a full rom set to remove games that wont be played on my cabinet?
I want to include only horizontal joystick games that will run on a p133.
Any tools to do this?
Re:Sorting Roms
« Reply #1 on: August 04, 2004, 02:13:48 pm »
Probably easier to hand pick the (classic) games that will run on that machine.  Many (most?) of them will be vertical tho...
You could use a FE to filter horizontal and joystick games, but you'd probably still have to manually remove the games which don't run properly.
Tiger-Heli
    • Tiger-Heli
Re:Sorting Roms
« Reply #2 on: August 04, 2004, 03:39:04 pm »
Start with hmove from http://mame.joymonkey.com/ (or vmove).  That should leave you with only horizontal games.
Next you could download and set-up emuloader (www.mameworld.net/emuloader) and show available games, sort by control type and highlight each non-joystick game and press delete.
From the remaining list, you would have to manually select the games that you PC can't handle and delete them.
