Author Topic: ArcadeOS screen could display but could not play games inside!  (Read 1261 times)
pachow
  • Last login:August 12, 2004, 12:41:21 pm
Hi all,
Very excited and many thanks to this forum and the website. It really change my life and I really build an arcade cabinet because I saw you guys really pay many effort to share the information.
I could not sleep at the last 2 days and today is the 3rd day. It was because I could not play my games through my machine and I don't know what is the problem!
Sorry, may be it's very impolite to ask questions at the first time but I really want you to give me a hand here.
I am using an arcade monitor with 15khz and the machine is made of Sega / Japan. I connect it with my jpac card and I use Arcade OS as the frontend. When I go into the main screen of Arcade OS, my arcade monitor could display clearly without any problem. However, when I select a game, the image disappears and just have some flash lines on it, other than this is nothing. When I press Escape button, no reaction.
I guess that there may be some setting wrong in my arcade OS software so could anyone tell me how to fix it? I frequency is Ok I think because I could see clearly when then menu starts. The image just got wrong when I select a game and then go into it.
The second question is the sound card problem. I bought a sound card and install the dos driver in somewhere. What I do is I go to dos window (I use WinXp) by pressing cmd, and then I run the autoexec.bat that is what the sound card driver located. After that, I run the arcade os but still not sound.
I sincerely hope that someone could read this message and be able to help me so that I could have a good sleep. You know, it's very painful when you have questions but nobody could help you. Moreover, you could imagine the painful picture is that, you have a big big arcade cabinet in front of you but just could not work!
Sincerely Yours
Paul in Hong Kong
SirPeale
  • Green Mountain Man
Re:ArcadeOS screen could display but could not play games inside!
« Reply #1 on: August 01, 2004, 01:58:08 pm »
The problem is that you're using Windows XP, and ArcadeOS is designed for DOS and using DOS Mame.
