Author Topic: Wiring Sega MC 2000-S Monitor  (Read 1457 times)
lostboy4480
  • Last login:January 29, 2026, 12:27:18 pm
« on: July 26, 2004, 03:18:09 am »
I have a Sega MC 2000 S monitor from and old turbo cab that I am going to try to wire up and use as a test monitor for some Jamma boards I have.
I just want to make sure of one thing.
I have an ISO transformer 110/100 for the main suppply but there is also another power line that goes to a small board on the top back side of the monitor.  I have looked in the manual and it says that it is to be hooked up to 100v or 120v.
I just want to make sure that it's OK to hook this up directly to my distribution block (so it is non isolated) or does this need to be isolated as well.
Thought I had better check with you experts and I wanted to be safe rather than sorry :)
Thank you
Edit due to my terrible descrpition of what part I am on about I have highlighted the part in the manual.
« Last Edit: July 26, 2004, 03:34:52 am by lostboy4480 »
Cabinets
NBA Jam
Golden Tee 2005
PGA Tour Golf Team Challenge
Tekken 5: Dark Resurrection
Generic Taito (Project)
Ken Layton
  • Guru
  • Technician
Re:Wiring Sega MC 2000-S Monitor
« Reply #1 on: July 26, 2004, 08:49:35 am »
The "Where does this go" goes to the degausser coil. You can hook that straight to either 100 volts or 120 volts ac (No isolation needed for that function). Be sure to wire in a momentary pushbutton switch as the coil will burn up if energised more than a few seconds.
lostboy4480
« Reply #2 on: July 26, 2004, 10:02:06 am »
Thank you Ken, that was just what I was looking for.
Cabinets
NBA Jam
Golden Tee 2005
