Author Topic: Donkey Kong Monitor  (Read 3145 times)
adam942
  • Last login:July 28, 2004, 05:38:29 pm
Donkey Kong Monitor
« on: July 17, 2004, 02:29:21 pm »
Hello, I am new here so please excuse any ignorance/noobisms.
The other day I acquired an original Donkey Kong arcade machine. There are a few minor flaws, but most of them deal with the outside of the cabinet. Anyways on problem that really irks me is my monitor screwing up. On the left side of the screen there is about 1 inch of the monitor that is blank. The rest of the screen works fine.
I have already tried changing the horizontal alignment and that did not work. Nothing will appear in that 1 inch area(from top to bottom). If anyone knows what the problem might be please help me out.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re:Donkey Kong Monitor
« Reply #1 on: July 17, 2004, 02:36:24 pm »
You need a cap kit and someone to install it for you if you haven't worked on  monitors before.
Zanen Electronics
1-806-829-2780
Donkeykong  usually had a Sanyo 20-EZV. But you should open it up and double check.
Later,
dabone
MonitorGuru
« Reply #2 on: July 17, 2004, 03:40:39 pm »
Typical Nintendo Sanyo 20-EZ problems.. vertical scrunch (remember your monitor iin a DK s twisted 90 degrees counter clockwise as compared with a horizontal monitor/tv set, so vertical to the monitor is horizontal to your eyes)  Therefore you adjusting horizontal on the monitor actually moves the screen up and down.  You would want to adjust vertical size/position instead to get YOUR screen to move left/right.
I bet it's not really missing the stuff, its just all the print for the first 1" of screen is scrunched into the first few lines that are there.
A standard cap kit will fix this.  There are 2 cap kits available. One has an extra 10 or so caps that may or may not need to be changed. If this is your only problem the standard kit will work, but it is a pain to remove the chassis from a sanyo monitor so you may as well replace all the caps at once and get 20 more years of life out of it.
The best/easiest place to order is http://www.therealbobroberts.com   the standard kit is $5 and the deluxe I think is $7.  He does have a flat $6 for initial 2 pounds shipping per order, but perhaps you can find other stuff you need to throw in to make it work for you. I dont know what Zanen charges for shipping.
adam942
« Reply #3 on: July 17, 2004, 04:02:35 pm »
With the proper research do you think that is something I should try on my own(replacing the caps). Or is it way beyond a beginners ability?
Ken Layton
  • Guru
  • Technician
« Reply #4 on: July 17, 2004, 07:35:02 pm »
Nintendo Sanyo monitors are not the easiest to do. Best let a professional fix it for you. Remember, if you attempt to do things yourself and you screw it up most professional won't touch it or if they do then it'll co$t you.
adam942
« Reply #5 on: July 18, 2004, 11:43:52 am »
Well I guess I better let someone else do it then. :  ) Thanks for all the replies. If anyone cares I might post some before and after pics of the machine when I am done.
