Author Topic: Mamewah problem  (Read 1669 times)
Pac-man
  • Last login:June 07, 2006, 02:16:06 pm
Mamewah problem
« on: July 13, 2004, 03:59:54 pm »
Does anyone else have a problem with very long lists of roms in mamewah? I have thousands of nes roms, they all show up i think but when i try to switch emulators it freezes and dies.
Anyone know if there is a known bug in mamewah for this?
Re:Mamewah problem
« Reply #1 on: July 13, 2004, 05:55:07 pm »
Try leaving it for *ages*...it probably hasn't died but it just taking a looong time.
The only solution is to filter your lists down as small as you can, and only flick between the smaller lists  :-\
This only happens with Win98, and I will try to fix it when I re-write the core...
Pac-man
Re:Mamewah problem
« Reply #2 on: July 15, 2004, 01:52:53 pm »
Does it not do this with win 2000 cos i could install that. Also how long do you think before you "re-write the core" is it worth me waiting. (Not trying to rush you or anything) It would take me hours to filter the lists, i have all the goodnes nes roms and snes etc etc. Maybe i should just instal win 2000
Re:Mamewah problem
« Reply #3 on: July 16, 2004, 07:08:16 am »
Yes it should work fine in Win2k...but I don't want to be responsible for you having to install a new OS!
To be honest it will be a while until I get to that re-write...I am re-writing a ton of other stuff atm, but I have a feeling I will need a rest after that...
Pac-man
Re:Mamewah problem
« Reply #4 on: July 16, 2004, 11:44:49 am »
Installing win 2k aint too bad cos i have two hdd, one for os on for all the arcade stuff so its only a matter of redoing that. Ill do that, its the easiest way round. Thanks
