Author Topic: Video problems...  (Read 1820 times)
Totallyout2lunch
  • Last login:July 14, 2008, 01:15:43 pm
  • Tempory nOOb
    • Tree House H.Q.
Video problems...
« on: July 08, 2004, 03:07:43 pm »
I just picked up a jama cam from a bloke down the road. I saw it working, so no worries or so I thought.
I got the cab home, put in a fav PCB just to test you understand, plugged it in, and it seems that the monitor has got buggered.
All i get it a white spot in the iddle, with a few flickering colors in the spot. I can hear the game in action if I hit the Player 1 button, it all seems to be ok there, so what is the problem with the monitor.
Monitor is a Samsung 20' (ish).
Today I marched us to the edge of the abbyss...
Tomorrow we go Forward!
Windows leads to anger,
Anger leads to hate,
Hate leads to Linux
Ken Layton
  • Guru
  • Technician
Re:Video problems...
« Reply #1 on: July 08, 2004, 06:53:06 pm »
Was the monitor securely bolted down when you moved the game to your place? Could any small pieces like screws or nuts have fallen on or under the monitor's main circuit board? If you tap the metal frame of the monitor with a screwdriver handle does the picture suddenly come back to normal for an instant?
Totallyout2lunch
  • Tempory nOOb
    • Tree House H.Q.
« Reply #2 on: July 09, 2004, 04:50:13 am »
Yes the monitor is securly fastened, it hardly moves if I push the frame. If I wobble it the dot dissapears sometimes, but I have not seen it come to full screen.
There is enough space under the circuit board for a screw not to touch the rest, but I will check again.
Which part do you want to tap with a screw driver? I'm a little uncertain, as I am not sure which parts are the really dangerous bits!!!
Cheers.
Hate leads to Linux
Ken Layton
  • Guru
  • Technician
« Reply #3 on: July 09, 2004, 10:37:55 am »
Just tap lightly the metal monitor frame anywhere with an insulated handle of a screwdriver or the wooden handle of a hammer. What you are doing is seeing if the vibration causes the picture to come back on for an instant. Chances are your monitor may have some bad solder joints.
Totallyout2lunch
  • Tempory nOOb
    • Tree House H.Q.
« Reply #4 on: July 14, 2004, 03:02:31 pm »
I have given it a good few taps, and not much happen, sometimes the white ball moves a little, but thats it, no full picture.
I would guess that its dead? Is it worth geting a professional in to look at it, or just buy a new one from happs?
Hate leads to Linux
MonitorGuru
« Reply #5 on: July 14, 2004, 04:57:23 pm »
It sounds like your yoke wire became detached... Either directly on the circuit board (most likely) or on the yoke itself.
This would cause both a horizontal and vertical "collapse" where you only get a bright dot in the center of the screen instead of a normal raster.
Be sure NOT to run the monitor very long (like only a few seconds) like this, otherwise you will end up buring in a horrible brown spot in the middle of your screen as nothing is deflecting the electron beams across the screen.  Technically you are probably buring that point well over 77,000 times faster than the rest of the screen (240 vertical rows * 320 horizontal columns), or 1 minute on = 2 months of normal never-turned-off use.
Look for a grey plug with a Red, Yellow, Green and Blue wire running from the copper windings around the back of the tube (the yoke) plugging onto the main circuit board.  If it's off the connector, press down securely (with the macine UNPLUGGED).
If its on, then, as Ken mentioned, take something totally insulated (like a piece of cardboard) and press against the connector and see if the screen comes back momentarily with the monitor on. If so, you will have to discharge the monitor and remove the board and resolder the pins which probably have cracked their solder joints from moving.
Totallyout2lunch
  • Tempory nOOb
    • Tree House H.Q.
« Reply #6 on: July 22, 2004, 06:53:57 am »
Thanks for the help...
<slaps himself around the head>
I have found a cable that was not conected correctly, plugged it in, and it now works fine. Its the one thet connects to the board, so you can put it in slot 1 for screen to face one way, or slot for a 180degree rotation.
</slaps himself around the head>
Hate leads to Linux
Ken Layton
  • Guru
  • Technician
« Reply #7 on: July 22, 2004, 10:51:36 am »
Sounds like you found the yoke connector alright. Glad it's working. ;D
