Author Topic: 25" S-Vid TV  (Read 2361 times)
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
25" S-Vid TV
« on: July 06, 2004, 02:46:13 pm »
Does anyone know of a 25" TV that has S-Video. I have looked high and low. A 27 is just barely too big to fit. Anyone have any ideas?
Truecade
  • Last login:April 05, 2024, 07:00:29 pm
Re:25" S-Vid TV
« Reply #1 on: July 08, 2004, 10:57:01 am »
I looked high and low for a 25" TV with s-video and came up empty.  RCA used to make one, but it was discontinued about two years ago.  I checked every electronics store I could think of, and the only 25" TVs I could find just had composite input.
I'm assuming you're looking for a 25" TV because your cabinet interior width is 25", and most 27" TVs are just slightly over this width.  I bit the bullet and got a D9200 arcade monitor even though it was 2x the cost of a 27" TV.  And I must say I have no regrets.   Go with the wells gardner D9200, it will fit perfectly in a 25" cabinet.
DaemonCollector
Re:25" S-Vid TV
« Reply #2 on: July 08, 2004, 01:45:12 pm »
A 27 will fit in the cabinet itself, but the brackets for the speaker shelf just hit it :( A Small form factor 27 can fit, needs to be under 32" Diagonal with the case. Would it be THAT bad to strip the case from a TV? Or is that really bad?
Todd H
  • Last login:August 26, 2024, 02:23:32 pm
  • It's Gameday!
Re:25" S-Vid TV
« Reply #3 on: July 08, 2004, 09:06:40 pm »
Will a 24" do?  Wal-Mart has:
http://www.walmart.com/catalog/product.gsp?product_id=2601426&cat=136944&type=19&dept=3944&path=0%3A3944%3A121791%3A136944
If I run across more I'll let you know.  I seem to remember quite a number of 24" TV's with S-Video.
DaemonCollector
Re:25" S-Vid TV
« Reply #4 on: July 08, 2004, 10:44:22 pm »
I want to try and avoid a flat screen TV, thanks for looking though
Todd H
  • It's Gameday!
DaemonCollector
Re:25" S-Vid TV
« Reply #6 on: July 09, 2004, 07:18:20 pm »
Here's one:
http://www.sanyo.com/entertainment/televisions/stereo/index.cfm?productID=754
Damn, that ones close, but the can is only 26 inches wide, that thing has speakers, makes it huge. :/
Todd H
  • It's Gameday!
Re:25" S-Vid TV
« Reply #7 on: July 09, 2004, 10:45:34 pm »
I'm gonna make it my mission to find you the right TV!   :)
Edit:
How's this one?
http://www.sharpusa.com/products/ModelDetailedSpecs/0,1161,1281-,00.html
« Last Edit: July 09, 2004, 10:58:24 pm by Todd H »
DaemonCollector
Re:25" S-Vid TV
« Reply #8 on: July 09, 2004, 11:20:50 pm »
Saw that one, I think it might be an inch too deep :( I'm starting to think I may have to find a used arcade monitor instead. :/
Edit: Thank you for helping me with this too :)
« Last Edit: July 09, 2004, 11:21:36 pm by DaemonCollector »
midgey
  • Last login:July 13, 2004, 10:44:44 am
Re:25" S-Vid TV
« Reply #9 on: July 13, 2004, 11:51:22 am »
Depth is probably the easiest of dimensions to remedy.  If you're not afraid to cut the back panel of your cabinet, that one would probably work.
Now if only I could find a TV that was a little under 24 inches wide and has S-video, or if somebody has a suggestion on how to make the opening of a Space Duel cabinet about an inch wider.
