Author Topic: Magnavox 25" with 8 Liners chassis  (Read 1567 times)
lostboy4480
  • Last login:January 29, 2026, 12:27:18 pm
« on: June 27, 2004, 11:52:50 pm »
I have a working 25" Magnavox TV which I am going to check the  vertical ohms on to see if it is compatible with the 8 Liners chassis but I have a quick question.
When watching TV on it, something that is ment to be Blue appears to be a more green/blue rather than a strong blue.
I am just wondering if this would be something to do with the tube or the chassis.  So would a new chassis fix this problem.
Thank you for your help
Cabinets
NBA Jam
Golden Tee 2005
PGA Tour Golf Team Challenge
Tekken 5: Dark Resurrection
Generic Taito (Project)
Ken Layton
  • Guru
  • Technician
Re:Magnavox 25" with 8 Liners chassis
« Reply #1 on: June 28, 2004, 12:03:42 am »
Could be that your Magnetbox chassis has lost it's color/tint settings.
lostboy4480
« Reply #2 on: June 28, 2004, 12:08:00 am »
Thank you for the reply Ken,
Thats what I was hoping someone would say.  So a new chassis should have this problem. (If I am understanding you right)
Many Thanks
Cabinets
NBA Jam
Golden Tee 2005
Ken Layton
  • Guru
  • Technician
« Reply #3 on: June 28, 2004, 12:15:15 am »
Your adjustment/setup menu on your Magnetbox chassis may be at fault. Replacing it with an 8liners chassis may fix it if you were wanting to use it as an arcade monitor.
