Author Topic: WG D9200 and non-mame emus  (Read 871 times)
Effayy
  • Last login:August 18, 2006, 02:09:07 pm
  • Slowest....Cab Builder.... EVER.
« on: June 21, 2004, 01:18:32 pm »
Hi guys,
I apologize if this question has been answered, I did search, but although my question has been touched on, I didn't see it answered.
I've begun work on my cabinet, and made all of my measurements on the assumption that I'll be buying a WG D9200.  Luckily I haven't made any cuts in the MDF yet because something popped up in my head this weekend.
I was originally planning on having a MAME-only unit, but now I've begun to lean towards supporting older consoles that I've owned over the years as well.
Consoles worked via connection to a TV, and looking at a frequency chart in the FAQ, I saw:
resolution horizontal bandwidth # lines # colors comparable
standard 15.75 kHz 240 unlimited CGA or NTSC TV
extended 16.5 kHz 288 unlimited CGA or PAL TV
medium 25 kHz 380 unlimited EGA
high 31.5 kHz 450 unlimited VGA
Since the D9200 is a 15/31 kHz monitor, does this mean that NES, SNES, Dreamcast, etc emulators will function?  If the answer is no, then I'll have to re-check my monitor options. :)
- FA
bdsjake
  • Last login:September 18, 2017, 12:08:23 am
  • livefree
Re:WG D9200 and non-mame emus
« Reply #1 on: June 21, 2004, 01:41:44 pm »
I think I can answer this.  If you are using emulators, then they use a standard windows resolution.  So yes the D9200 will work b/c it will handle 640x480 (some use 800x600 but its not supported by WG).   I use an Atari 2600 emulator with my D9200.
If you are talking about hooking up the original box, I don't know what problems you will have with video, but as someone else pointed out to me, you will have problems with sound.
