Author Topic: Adobe Illustrator Help  (Read 1709 times)
Evilpenguin
  • Last login:November 30, 2007, 06:53:35 pm
  • MegaMame
« on: June 10, 2004, 08:30:23 pm »
Hi all
If I download a marquee that is in .AI format how do I resize it to print the size that I need.  For example my marquee size is 23x6.
Jason
« Last Edit: June 10, 2004, 09:48:34 pm by Evilpenguin »
mahuti
Re:Adobe Illustrator Help
« Reply #1 on: June 10, 2004, 09:57:13 pm »
If you don't have access to Adobe Illustrator, you might ask someone to resize it for you.
If you do have access, There are a number of ways to resize, all of them not too complex. I'll be happy to post some ideas if that info is what you are looking for.
Evilpenguin
  • MegaMame
« Reply #2 on: June 10, 2004, 10:02:08 pm »
I downloaded the trial version of it, so yes if you could tell me how to resize it that would be great.
Jason
mahuti
« Reply #3 on: June 10, 2004, 11:42:41 pm »
Method 1.
1. Select View > Show rulers
2. Select > All
3. Hold "shift" then Click on one of the corner points
4. Drag down until it is the right size
Method 2.
1. Object > Transform > Scale
2. Select scale percentage
Method 3.
1. Use the scale tool (s)
2. Click on object (holding "shift")
3. drag until it is the size you want
Method 4.
1. Select the scale tool (s)
2. Double click it
3. Select percentage you would like to scale.
Version 3 & 4 might be good choices.... you might want to check the "scale strokes & effects" box.
