Author Topic: raine on arcade monitor  (Read 1968 times)
bloodyviking77
  • Last login:March 07, 2010, 07:01:38 am
« on: June 10, 2004, 09:07:09 am »
Just started to experiment with running raine (my cab is currently running a super-crappy pII-400  :))
I've got "arcade monitor mode" to work - . . .
except the top two inches of the screen sort of "fold over" to the right, sort of leaning over at about 45 degrees.
The raine.cfg file doesn't have much explanation for the four arcade monitor options that I can find (h timing, v timing, center x and center y), but says that
"Altering these values by any significant amount may lead to damamge to your arcade monitor, and you do so at your own risk", so I don't want to fiddle too much . . .
Any thoughts?
Shut up! Bloody Vikings!!
bloodyviking77
Re:raine on arcade monitor
« Reply #1 on: June 12, 2004, 09:27:39 pm »
*shameless bump*  :)
Here's a pic
bloodyviking77
« Reply #2 on: June 12, 2004, 09:29:28 pm »
here:
« Last Edit: June 12, 2004, 09:30:49 pm by bloodyviking77 »
bloodyviking77
« Reply #3 on: June 12, 2004, 09:32:55 pm »
and another pic:
mattv
  • Last login:June 10, 2022, 06:33:25 am
« Reply #4 on: June 14, 2004, 07:09:29 pm »
Congrats on getting this to work - looked at a while back and was scared off.
Oh, BTW, you might be able to fix your "top of the picture is messed up" problem by playing with the vertical strech settings in the emulator and the vertical size settings on your monitor.
bloodyviking77
« Reply #5 on: June 15, 2004, 08:56:44 am »
Thanks . . . I fiddled with the h.hold and v.size pots and eventually I've managed to get a pretty good picture.
Donpachi at 400mhz!! ;D
