Author Topic: Dead Hantarex MTC 9300 monitor  (Read 2119 times)
Lave Laar
  • Last login:January 04, 2022, 06:23:13 am
    • Freeware arcade related programs
« on: June 10, 2004, 06:00:00 am »
Yesterday I was using my arcademachine. Suddenly the screen goes black and the just a ticking sound comes from the back.
At back of the hantarex psu there is a label  "Supplies ok" and a red light for each +5 +12 -12 -5.  When i turn on the power the +5 +12 and -5 are flashing and making the ticking sound.  I suspect a fuse, but I like to be certain before I start fiddling around in there. The light behind the marquee is working.
So anyone have a solution for this ?
Bally
  • Last login:March 10, 2012, 10:19:24 am
  • Pinball and Arcade Tech
    • Flipperspill
Re: Dead Hantarex MTC 9300 monitor
« Reply #1 on: March 10, 2012, 10:08:41 am »
Same problem here and no one can help....the info i found are "they are crap" and "stay away"  :banghead:
grantspain
  • Last login:July 25, 2025, 09:21:43 am
« Reply #2 on: March 10, 2012, 10:53:22 am »
is this the chassis in the plastic box?
ticking is down to the power supply in trip because a short,normally on hanty monitors its down to bad caps,shorted hot,maybe a high voltage poly cap on the hot collector,sometimes the flyback
