Author Topic: Project64 & Mamewah  (Read 3941 times)
MameMe
  • Last login:June 08, 2005, 06:45:25 am
Project64 & Mamewah
« on: June 04, 2004, 07:08:50 am »
I've been trying to run Project64 within Mamewah with no luck.  So after failed attempts to figure out what's going wrong I went to a command prompt and ran the following command to see:
C:\Games\Project64 v1.5>Project64.exe "Mario Kart 64.zip"
But all I get is an error message of "Attempt to open file failed".  Any ideas how to run Project64 from command line?
The zip file(rom) is in the same location as the .exe, so I'm confused.
Re:Project64 & Mamewah
« Reply #1 on: June 04, 2004, 07:45:50 am »
Does Project64's documentation not say?
You could try running just 'project64', 'project64 /?' or 'project64 -?' to see if it has a help page...
« Reply #2 on: June 04, 2004, 09:58:25 am »
Either enclose the mario kart zip filename in quotes on the command line or get rid of the spaces in it.
  • Last login:July 02, 2026, 07:26:12 pm
« Reply #3 on: June 04, 2004, 06:19:50 pm »
you need a full path regardless... also as suggested, the windows command line can't handle a path with spaces in it unless you enclose it in quotes.
Dave Butler
  • Last login:October 27, 2016, 03:31:16 pm
  • What does this button do?
    • MAMEWAH Setup
MameMe
« Reply #5 on: June 05, 2004, 07:30:21 am »
Try this
http://www.mamewah-setup.co.uk/html/info_settings.html#Project64
That helped cool!  One problem left which isn't described on that link.  After playing a game in Project64(full-screen) and hitting ESC to exit the game, I end up back at the Project64 screen instead of going back to Mamewah.  How do I exit a game and close Project64 in one keypress?
« Last Edit: June 05, 2004, 07:39:43 am by MameMe »
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« Reply #6 on: June 06, 2004, 05:04:45 am »
Use the hacked exe version of Project64 available here: http://www.screenshotarchive.com/downloads_emus.htm
MameMe
« Reply #7 on: June 06, 2004, 08:43:35 am »
Stuzza saves the day..Kudos!  Thanks
