Author Topic: My New MAME Cabinet  (Read 2704 times)
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
My New MAME Cabinet
« on: May 29, 2004, 12:46:10 am »
Slowly but surely my plans for a MAME cabinet of my own are taking shape. I just finished the CAD drawing based on LuSiD's plans. Check out the pics:
http://www.geocities.com/tahnok1000/All1.bmp
http://www.geocities.com/tahnok1000/All2.bmp
http://www.geocities.com/tahnok1000/Playing.bmp
The artwork on the model is not what I am planning on using, but the panels will be black. If I can build the cab with no design errors I will make the CAD files public (created with Anim8or).
One thing I am not too sure about though is my monitor. For some reason it looks really small. It is a 24" screen, so I don't know why it seems small. What do you think?
I am making final adjustments to the plans and then cutting will begin! ;D
« Last Edit: May 29, 2004, 02:20:05 am by tahnok100 »
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
flampoo
  • Last login:March 20, 2014, 11:41:07 am
  • BYObsession
    • flampoo
Re:My New MAME Cabinet
« Reply #1 on: May 29, 2004, 12:53:35 am »
You can't link to images w/ geoshities. Change the extension of the filenames to .txt or just upload them to this site.
Tahnok
    • Table Arcades
« Reply #2 on: May 29, 2004, 02:23:21 am »
Sorry, I can't find another host right now. Copy and paste the above image URLs into the adress bar and they should work.
AmericanDemon
  • Last login:February 27, 2026, 01:01:31 am
  • Still an AmericanDemon
« Reply #3 on: May 29, 2004, 02:15:02 pm »
How did you measure your monitor?  The reason I ask is because it certainly looks more of a widescreen than a 4:3 ratio monitor.  Also Check your scale as the cabinet looks too tall for the distance between the ground and the CP.  Those are just my observations though.
Tahnok
    • Table Arcades
« Reply #4 on: May 30, 2004, 10:35:30 pm »
Hmm... It would seem that you are onto something. I just checked the model and it seems that some of the measurements were indeed off. It looks quite a bit better now.
BTW, the first picture was taken in perspective mode, which makes the cabinet look much taller. The second picture gives a better idea of what the cab will look like.
« Last Edit: May 30, 2004, 10:38:07 pm by tahnok100 »
