Author Topic: Linux, keyboard "delay" prevents full speed  (Read 2093 times)
vputz
  • Last login:August 23, 2010, 08:16:05 am
  • I'm a llobter!
« on: May 24, 2004, 01:23:53 am »
Here's a curious one.
Running xmame.x11, the keyboard (both the actual ps/2 keyboard and my minipac-based CP on USB) cannot generate events fast enough to play Joust.  I'm not sure what effect it's having on other games.
In other words, I can click as fast as I want, but there's no way to flap fast enough to gain height.
The interesting thing is that if I use a gamepad, I *can* generate events fast enough.
So I'm curious--what am I missing?  I think it has to be fixable through X somehow, but I just don't know how...
-->VPutz
eu4ria
  • Last login:May 23, 2004, 10:46:19 pm
Re:Linux, keyboard "delay" prevents full speed
« Reply #1 on: May 26, 2004, 12:33:17 am »
which distro are u using ?
You will probably need to look in you x config files. Its so long since I have played with X its hard to remmeber some of the names...
GUI's are for wimps  ;D
vputz
  • I'm a llobter!
« Reply #2 on: May 26, 2004, 01:39:35 pm »
Debian unstable/testing mix.
That's what I'm guessing, but I'm having trouble figuring what to change.  About the only options I've seen have been the delay between pressing a key and autorepeat and the delay between autorepeat signals, neither of which sounds like it'll work.  I'll probably try them anyway at some point.
-->VPutz
