Author Topic: Trouble with new MAMEwah 0.97 AND Butler's new MAMEwah setup  (Read 7502 times)
Dave Butler
  • Last login:October 27, 2016, 03:31:16 pm
  • What does this button do?
    • MAMEWAH Setup
Re:Trouble with new MAMEwah 0.97 AND Butler's new MAMEwah setup
« Reply #40 on: July 08, 2004, 04:33:17 pm »
Could you ZIP your 'Layout' and 'Files' folder and E mail them to me and I will have a look at them for you. :D
daveb@mamewah-setup.co.uk
Dave Butler
    • MAMEWAH Setup
« Reply #41 on: July 08, 2004, 05:24:52 pm »
Just put your layout file into my layouts folder to try it.
Got 'Runtime error 13' I think you may have been right about the Vrai and Faux. Changed them to True and False and it worked.
I am not sure how the languages work with windows but you may want to try changing the .LAY file to see if it works ;D
Also noticed that some of the numbers had a coma in them instead of a point, this will alter the size of the text if you get the layout working... ;)
Xelotath
  • Last login:December 18, 2010, 11:07:44 pm
    • My Destructoid Blog
« Reply #42 on: July 08, 2004, 05:42:01 pm »
Did you only change the false and true? Because it's not working. Maybe I have to replace the true false in every emu*.cfg files. I'll try this and post the result. BTW, thanks for helping me.
EDIT: Also When there is no layout the FE works, so I was playing with it. But I can't get my snapshots to show up, but they work during the screen saver.
« Last Edit: July 08, 2004, 05:48:51 pm by Xelotath »
Xelotath
« Reply #43 on: July 08, 2004, 05:52:10 pm »
This is still not working... did you test my layout folder with my files folder?
Buddabing
« Reply #44 on: July 08, 2004, 05:53:49 pm »
MAMEWAH Setup requires FM20.dll for something or other (transparent text box perhaps), but it cannot be distrubuted freely thanks to Micro$oft  :P.  On the MAMEWAH Setup site I believe it explains this and gives a link to where you can get the dll.
Joel on Software says, "The native Visual Basic Controls are not Unicode enabled.  You need to use Unicode enabled controls.
Microsoft provides the Microsoft Forms Controls for this purpose.  The "fm20.dll" is the DLL that contains these controls.  Simply add a reference to it from the VB IDE.
These controls are used by MS-Office/VBA and apparently are not distributable with your application."
Please read the wiki!
Xelotath
« Reply #45 on: July 08, 2004, 07:58:51 pm »
Does anybody on this forum use a french Windows and use MAMEWah? Because I'm pretty sure that's the source of my problem. Maybe that's a bug, I hope Minwah you'll check the thread.
