Author Topic: Reseize Sreen / ArcadeVGA --> Scart  (Read 4053 times)
FloLob
  • Last login:June 08, 2004, 07:35:10 am
« on: April 23, 2004, 06:35:54 pm »
I am running my ArcadeVGA via my selfmade VGA ---> Scart cable on a Grundig TV, and it runs flawless ..... except for
the Screensize. The Screen is too large in width and height for my TV-Set. I cant find a solution for adjusting the graphicscard signal. The Boxes for Screenadjustment in the driver tab are greyed out (i am using xp, the same in Win 98 SE).
Someone told me to open the TV-Set and adjust the screensize there ... but i am not willing to do that (lack of experience).
Advancemame didnt help either, i couldnt fit the whole picture on my TV.
Here is a quote from Andy / Ultimarc:
But there is one way we can use a TV very satisfactorily, which is going in via the RGB pins on a SCART connector (US readers look away at this point, SCART is a European standard!). This actually turns the TV into an arcade monitor because it by-passes all the signal-degrading PAL or NTSC decoder, We can even run native resolutions providing the TV is happy with non-interlaced screens.
Any ideas how to activate the screenadjustment-feature in the arcadevga`s driver ? Other solutions ? Right now the ArcadeVGA / TV combination doesnt satisfy my needs.
Any help is appreciated. Greetings from Germany.
b3atmania
  • Last login:November 25, 2005, 09:48:57 am
Re:Reseize Sreen / ArcadeVGA --> Scart
« Reply #1 on: April 24, 2004, 04:44:40 am »
The preset mode timings in the ArcadeVGA are not right for every monitor/TV. You will need to use somehting like AdvanceMAME. It comes with the advcfg utility that allows you to fit the picture to the screen and store the setting. Effectivily this will overrule the presets in the ArcadeVGA BIOS.
Cave
  • Last login:June 07, 2009, 10:27:58 am
« Reply #2 on: April 24, 2004, 08:13:40 am »
I've heard that alot of TV's have a hidden factory menu where you can adjust size and shape of the display, its activated by pressing certain combinations of buttons on the controller, can anyone confirm this.
cave
« Reply #3 on: April 24, 2004, 10:32:28 am »
That is correct, it can be difficult to find out how to access the service mode tho, since it is meant for service engineers only.  Try a Google search for 'grundig service mode' and include the TV model no...
StephenH
FloLob
« Reply #5 on: April 25, 2004, 06:10:16 am »
My TV is a Grunding CUC 3400 . No the newest one though.
I think there is no service menu available, it doesnt have an OSD.
But I managed to configure AdvanceMame with a good result.
Concerning picturequality i really can recommend using an ArcadeVGA and the selfmade VGA-SCART-Cable with a TV - Set.
Thx for your replies
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #6 on: April 25, 2004, 02:18:32 pm »
TVs are designed to overscan, a portion of the picture goes off the top/sides. So the picture size will nearly always need to be adjusted. Many TVs have enough adjustment in the user controls on the remote menus to do this (like my Toshiba), but some  you do need to go into service mode to get a wider adjustment range as someone mentioned.
The picture size adjustments in the Windows driver are greyed out for good reason: we are using a fixed frequency monitor so we can't change the picture size. It has to be done on the monitor.
ras2a
  • Last login:November 19, 2016, 02:21:26 pm
  • I drink, therefore I am!
    • Nolij
Re: Reseize Sreen / ArcadeVGA --> Scart
« Reply #7 on: December 06, 2004, 11:47:46 am »
I've not actually connected my TV to my AVGA yet,so don't know if I'll have any probs, but it's a Panasonic model (will check model no later).  Anyone know of where to look for Panasonic service modes?  I've got this link: http://www.calanan.com/panasonic/ but just wondering if there is anywhere else as I'm fairly sure my model isn't on the list.
Just thought I'd look into it in case I have any probs with sync etc
ta
Craig
