Author Topic: Mounting with 2 2x4's  (Read 1545 times)
depressd
  • Last login:April 04, 2019, 04:29:33 am
« on: April 17, 2004, 12:55:19 pm »
Do you guys think using 2 2x4 to mount my D9200 will be sufficent? The 2x4 will be screwed through the side of the arcade with 2 12 x 1 1/2 flat philips head screws. This will be covered with laminate afterwards.
Ken Layton
  • Guru
  • Technician
Re:Mounting with 2 2x4's
« Reply #1 on: April 17, 2004, 01:09:40 pm »
Actually you should attach the 2x4 with a couple of carriage bolts thru them. That will ensure the 2x4 will stay attached to the cabinet.
Remember that when a game gets moved the weight of the monitor will be on that 2x4 so it must be secure.
depressd
« Reply #2 on: April 17, 2004, 01:36:53 pm »
I would prefer not to have carriage bolt sticking out on the side. Is there any other way I could use the 2x4 with additional support? I could add additional 2x4 supports on the metal monitor frame.
bdsjake
  • Last login:September 18, 2017, 12:08:23 am
  • livefree
« Reply #3 on: April 19, 2004, 10:27:32 am »
I assume you are using 2x4 to go across the cab, to attached the monitor with 6 bolts (3 top, 3 bottom).  I used "L" brackets (literally look like an L) to attach my 2x4's, for D9200 mounting.  2 to each side, on on top, one on bottom of the 2x4. But, I wouldn't rely on just 2 2x4's, I also built a shelf that most of the weight of the monitor rests on.
« Last Edit: April 19, 2004, 10:29:02 am by bdsjake »
depressd
« Reply #4 on: April 19, 2004, 04:15:46 pm »
Thanks, bdsjake
I have a shelf incorporated into the cabinet. So I hope using the 2 2x4 and the monitor shelf will be sufficent. Is there any instability in your setup?
bdsjake
  • livefree
« Reply #5 on: April 19, 2004, 04:49:06 pm »
no instability, its rock solid with combination of shelf and 2 2x4's.
now, with weight of monitor up that high if you try to move it you will find it top heavy, so be sure to get help moving!
