Author Topic: [OFF-TOPIC] Good ears, help me please !  (Read 2824 times)
AMIGrAve
  • Last login:June 11, 2024, 03:56:35 pm
« on: March 22, 2004, 01:29:26 pm »
I'm really sorry for this big off-topic post, but I need help from people who's english is their mother tongue.
I just receive my arcadeVGA today, and I can't use it because the motherboard I wished to use for it just stopped working yesterday. I just removed the DDRAM memory, I used it on another computer then put it back to the motherboard and since that moment the silly Asus POST reporter shout something I don't understand with a voice of a woman that probably ate ducks and all this outputed on the PC speaker at less than 8Khz, and I would really apreciate if one of you could hear to this file and tell me what he ear !
I know it is not monitor/video related but as I met friendly dudes in this forum and as you probably are the only ones who can understand how i can be frustrated to have this arcadeVGA and can't try it ...
I'm not good at english so I'm not sure to understand what the voice says, but I first tought the message was "System battery no charged",  so I tested the cmos battery and even replaced with other ones without success. I also tried to CLR_CLEAR the cmos memory. I tried to take the memory back to another computer, it is working good. The HD are spinning up, the video doesn't output anything, the cpu fan is ok, I don't understand what it could be.
Please, help me !
desmatic
  • Last login:June 25, 2006, 02:25:53 pm
    • Easy MameCab
Re:[OFF-TOPIC] Good ears, help me please !
« Reply #1 on: March 22, 2004, 02:45:00 pm »
I haven't the foggiest idea what they are saying in the recording, but I suggest you take everything out of the PC that isn't essential (just remember where it went), and then swap out each component until you get a working setup.  It's the only real way I know of for nailing down a tricky hardware problem.
And to answer a previous question, I use Windows 98SE in dos mode for my cab.
JasonF
  • Last login:June 08, 2005, 08:37:35 am
  • "Jason F" on RGVAC!
« Reply #2 on: March 22, 2004, 02:48:32 pm »
Wow, that is hard to understand.  I grabbed a copy of an ASUS manual from the web, and based on the Vocal POST messages, I would say that the closest one that I found was:
System Failed Memory Test.
It definitely starts with "System Failed" and ends in "Test".  The only possible error messages like this (listed in this manual) are:
"CPU", "Memory", and "VGA".
Personally, it sounds more like "System Failed Load Test", but I don't know if that's a valid vocal POST for your particular MB.
AMIGrAve
« Reply #3 on: March 22, 2004, 03:09:47 pm »
Thanks dudes,
Desmatci: i already unplugged/removed everything except the cpu and the memory, i'm gonna try other memory but i won't be able to test another cpu.
JasonF: yeps, i saw this pdf, but I didn't found what could match with the error i hear
Gonna try to swap memory ...
desmatic
    • Easy MameCab
« Reply #4 on: March 22, 2004, 08:58:48 pm »
I wouldn't worry about the cpu.  Unless you're up to freaky overclocking, they almost never fail.  Neither does memory, however, you may have a memory type that is setup incorrectly or incompatible.  For example, on some asus motherboards with the nforce chipset, corsiar memory wont work.  No boot, nothing.  Also, some motherboards are a little overly aggressive with their timings.  They pick 2 instead of 2.5 or 3.  You could also try jumpering a lower bus speed, say 100mHz.
If you know your system specks, feel free to post them.  Particuarly the mobo chipset, ie intel, via, nvidia, sis.
AMIGrAve
« Reply #5 on: March 24, 2004, 03:57:25 am »
Thanks for your response dudes, I finally eared the message in slow motion many times and I also agree that the closest message should be "System failed memory test" even if it is from miles to what I eared first ! ;-)
Anyway, I googled on the keywords a7v333 "system failed memory test"
http://www.google.com/search?q=a7v333%20%22system%20failed%20memory%20test%22&ie=UTF-8&oe=UTF-8
And I was surprise to see that a lot of people had the same problem as me with this mother board ! It seems that the a7v333 is the "black sheep" of asus as it is told in this forum :
http://www.sysopt.com/userreviews/mboards/reviewhtml/AsusTek_A7V333.html
So, I finally bought a new motherboard, I'm currently installing debian on the system and I guess I'll be playing to my fav' games on my cab very soon now !
Thanks again for your replies guys !
