Author Topic: mame32 problem with ini file, help please.  (Read 1192 times)
Apollo
    • Eight Bells
« on: March 12, 2004, 02:13:05 am »
I am using Mame32 and the ini file appears to be read only ( I think this is why I have to re-specify the directories every time I open mame ). I have tried going into properties and removing the tick from the read only prompt box but it just returns to read only again. Any ideas or do I need a different mame32 version?
Confused.
  • Last login:May 26, 2026, 01:01:55 am
Re:mame32 problem with ini file, help please.
« Reply #1 on: March 12, 2004, 10:26:10 pm »
If you are in 2k/xp... go to the root directory where mame is installed.... adjust the folder options so that they aren't read only and apply the change to all files inside.
Apollo
    • Eight Bells
« Reply #2 on: March 13, 2004, 05:51:06 pm »
Thanks Howard I'll give it a go. Cheers.
Apollo
    • Eight Bells
« Reply #3 on: March 14, 2004, 08:50:20 pm »
Well I tried resetting the main MAME folder properties and unticking the read only box but it doesn't work. When I go back into the properties the tick in the read only box is back. Any advice?
Bomber
  • Last login:July 20, 2006, 01:48:39 am
« Reply #4 on: March 14, 2004, 08:58:36 pm »
Try making a copy of the ini file, rename the original file and rename the new file to what the old one was called. I'm sure I could have explained that a lot easier!
Make sure you're not running Mame32 when you're playing with the permissions as well cause that might screw it up.
Never get into fights with ugly people - they have nothing to lose.
