Author Topic: Mamewah pc games  (Read 2262 times)
beek
  • Last login:March 22, 2020, 11:25:49 am
Mamewah pc games
« on: March 11, 2004, 11:26:11 pm »
1.  I've set the exe to "PC"
2.  set the correct rom path.
3.  put a batch file with the lnk extension in the rom path dir.
I get a subscript 9 error when I try to refresh the rom list.
Any ideas?
beek
Re:Mamewah pc games
« Reply #1 on: March 12, 2004, 12:20:26 am »
If I look at the file using oscars renamer I see it is named "wolf3d.lnk.pif"  I renamed it to just "wolf3d.lnk" but it will no longer launch manually but now mamewah sees it. and I don't get the subscript 9 error.
Is this a windows xp problem?
Re:Mamewah pc games
« Reply #2 on: March 12, 2004, 05:10:36 am »
The .PIF means that it is a DOS program...Unfortunately MAMEWAH doesn't seem to like DOS programs (it must have .LNK extension as you've found)...
You could probably make a batch file to launch the file, and then set the ROM Extension to 'BAT' and see if that works...
housenm
  • Last login:January 26, 2004, 04:52:10 pm
Re:Mamewah pc games
« Reply #3 on: March 12, 2004, 03:13:36 pm »
have got the same problem in xp with mamewah.
When i set it to bat and write batch files i get the error.
I don't have this with lnk files.
What i did was to make a bat file and then create a shortcut to it.
This has the extension lnk so mamewah sees it and the lnk file
launches the batch file...
Great fe, thanks.
Re:Mamewah pc games
« Reply #4 on: March 15, 2004, 11:52:05 am »
Great fe, thanks.
Good idea, that's the best way around it for now...
beek
Re:Mamewah pc games
« Reply #5 on: March 15, 2004, 06:39:13 pm »
That worked great! Thanks.
