Author Topic: -VENDOR- Gary’s Hobbies: free arcade panel designer + custom screen masks  (Read 25253 times)
0 Members and 34 Guests are viewing this topic.
GarysHobbies
  • Last login:September 25, 2026, 10:39:07 pm
Hey BYOAC builders — Gary here from Gary's Hobbies. I'm excited to share a couple of things I've been building for custom arcade cabinets.
Build your control panel before you cut it. My free arcade panel designer lets you set the panel size and shape, try familiar joystick/button layouts, add components, and move everything around at scale. The attached screenshot is a two-player Vewlix-style layout made in the live tool. Try your own here: https://garyshobbies.com/configurator
Give the screen a clean finish. I also make custom-cut plexiglass and black ABS screen masks that hide the monitor frame and unused area. Enter the cabinet's measurements, review a dimensioned proof, and approve the fit before I cut the parts: https://garyshobbies.com/bezel
If you want a panel made for your build, I can quote a wood control panel, a clear plexiglass overlay, or both from your design. I also cut arcade plexiglass for display covers and marquees. You supply your own controls, electronics, and artwork.
The second attached image is a before/after illustration of the screen mask idea, not a photo of a finished customer's cabinet.
I'd love to hear what you're building. What panel layout or screen fit has been the hardest part of your cabinet? I'm especially interested in feedback on layouts and measurements the designer should support next.
— Gary
