Author Topic: Arcade controls on original Xbox  (Read 3455 times)
Fatboy
  • Last login:October 07, 2025, 09:21:29 am
« on: October 01, 2025, 04:35:01 pm »
 I have an arcade cabinet running emulation station on a raspberry pi, with the joystick buttons and controls as seen in the picture. I've also got an original Xbox (the first they brought out) that's been modded to play many emulators. I've tried to connect the arcade machines controls via a usb/to Xbox controller adaptor cable but nothing works. Is there a different type of adaptor I need to use to be able to use the arcade controls with the Xbox?? Any help appreciated 👍🏻
  • Last login:Today at 03:29:09 am
Re: Arcade controls on original Xbox
« Reply #1 on: October 01, 2025, 04:59:21 pm »
An encoder needs to be in "x-input" mode for the Xbox to recognize it.
Not sure if your "zero-delay" style encoder can do that or not. (some do, some don't)   :dunno
ulao
  • Last login:February 11, 2026, 04:59:59 pm
« Reply #2 on: October 03, 2025, 01:03:52 pm »
 If you want something on the original, you can use a Bliss-Box.
2 ways
1
 Get a GPA single adapter, and a Bridge.
Use the signal adapter in arcade mode.
Use the Bridge in Xbox OG mode
2
Get a GPjr
Use the GPjr in arcade mode and flash it with the Xbox firmware
I can help with detail if needed.  Here is an old video of it
« Last Edit: October 03, 2025, 01:07:56 pm by ulao »
Fatboy
« Reply #3 on: October 05, 2025, 08:36:43 am »
Thanks for the replies. Can you point me in the right direction and a bit more detail regarding GPjr and GP adapter etc??
  • Last login:Yesterday at 04:10:26 pm
« Reply #4 on: October 05, 2025, 12:41:48 pm »
Get the X Arcade encoder and move on with life
ulao
« Reply #5 on: October 07, 2025, 06:41:35 pm »
They are found here
Bliss-box.net
I own both. the GPA IMO is by far the best but you need the Bridge to use it on the Xbox.
the GP is a production version of the GPjr. So they are the same just that the GPjr requires soldering and assemble where the GP does not.
They are USB adapts and work on anything USB. to use them on the xbox, just flash the special xob firmware, quite simple.
There is a discord for support, very fast, very helpful.
