Author Topic: Testing Composite Blending from PC – VideoAMP + Antonio Villena VGA → Composite/  (Read 20874 times)
Rion
  • Last login:May 09, 2026, 09:35:51 pm
  • 240p, 480i
Hi everyone,
I’ve been experimenting with composite blending from PC using the VideoAMP (Pro Model)   together with Antonio Villena’s VGA → Composite/S-Video transcoder (with sync combiner)  .
The setup uses the VideoAMP’s VGA passthrough to feed into the transcoder while also outputting SCART RGB at the same time. This way you can see a side-by-side comparison of RGB SCART vs Composite directly from a PC on a CRT.
I recorded two Sega Genesis games to show the effect:
🔹 Streets of Rage 2
🔹 Shinobi III: Return of the Ninja Master
Many of us are used to seeing consoles through composite, with its characteristic color bleed and blending artifacts. This method shows how you can replicate that look straight from a PC, while still keeping the option of razor-sharp RGB.
Curious to hear your thoughts?
Do you prefer the crisp RGB look, or the softer composite blending that feels closer to how many of us first played these games?
Equipment used:
- Video out:
  • VideoAMP V5 Pro (RGB SCART + VGA passthrough)
  • Antonio Villena VGA → Composite/S-Video transcoder (sync combiner model)
    → Connection chain: VideoAMP VGA passthrough → HD15 VGA cable → Antonio Villena transcoder → RCA male-to-male plug straight into the CRT composite input (for the cleanest possible composite signal)
- Audio chain:
  • Input      → 3.5mm audio from PC → Behringer HA400 headphone amplifier (input) with ground loop noise isolator
  • Output 1 → 3.5mm to VideoAMP V5 Pro audio input (3.5mm) with ground loop noise isolator
  • Output 2 → 3.5mm to dual RCA (L/R) into the CRT with ground loop noise isolator
  • Output 3 → 3.5mm to LM-40 Passive Line Level Attenuator with ground loop noise isolator
- Recording:
  • Samsung Galaxy A33 smartphone (video capture)
  • UGreen USB-C sound card (audio interface)
« Last Edit: September 02, 2025, 12:47:51 pm by Rion »
Zebidee
  • Trade Count: (+9)
  • Online Online
  • Last login:Today at 05:40:02 pm
Interesting. Nice to see the VideoAMP put to good use. I have an older version.
Not sure I'll ever be a convert to composite generally, but appreciate that some console games actually look better like that.
Can you please provide a pic or vid of the video input chain setup? Particularly the VideoAMP/VGA cable/transcoder/scart out?
Rion
  • 240p, 480i
Nothing really special here.
It's a little cramped behind the CRT so here is a more detailed chain connection description
- Video out:
  • PC (R9 380X) -> DVI-I/VGA -> VideoAMP v5 Pro - VGA Input
  • VideoAMP v5 Pro - Scart Output -> Scart Cable -> Scart Input 1
  • VideoAMP v5 Pro - VGA Pass-through -> VGA Cable -> Mini-VGA gender changer -> VGA → Composite/S-Video transcoder -> Composite input on CRT
- Audio chain:
Here are some picture that shows how the - VGA → Composite/S-Video transcoder is connected.
I'm planning on attaching the VGA Female to Female gender changer with some #4-40*5+L Hex Standoffs Male-Female (outside thread 10mm).
Just haven't gotten around to it at this point (read: I forget where I put them  :lol )
Zebidee
  • Trade Count: (+9)
  • Online Online
Thanks! Much as I imagined.
I created a pic to roughly mirror what you are doing (below), using VideoAMP with GreenAntz. I guess I should now actually try to drive the two outputs (RGB + component/YPbPr TVs) simultaneously.
This should be sufficient to drive both TV outputs. I wonder if it is able to drive two *arcade monitor* outputs at full brightness, or even one arcade monitor + TV, as arcade monitors expect more powerful RGB signals (~2vpp or more). Reviewing the THS7375 specs (I understand this is the amp chip used), I think it might!
Rion
  • 240p, 480i
Just to clear this up 🙂
The standard versions (v1–v4 and the normal v5) can only run one output at a time so it's either SCART or VGA passthrough. The reason you’ve seen me running both SCART and VGA together is because I have one of the very few v5 Pro units, which supports true dual output. That version was never released widely and only a handful were built, and mine came out of some specific testing and feedback discussions with njz3.
Over time I also suggested a few smaller things that ended up being useful for everyone:
  • Adding a DIP switch to convert RGBHV → RGBS, so you don’t need an external sync combiner.
  • Adding stability tabs in the 3D case so the ports are held more securely.
  • Writing a wiki page for the VideoAMP when using CRT EmuDriver setup to make it easier for new users.
I only mention this because it helps explain why my setup doesn’t match what you’d normally expect from a stock VideoAMP since only the Pro model will do SCART + VGA simultaneously.
So in short:
  • Normal units = single output at a time.
  • Pro unit = special small batch with dual output.
  • Some features (like the RGBHV→RGBS switch and case reinforcement) came from ideas shared during testing.
I also don’t think njz3 or Bandicoot would be against making more Pro units if someone really needed that functionality. It never became the standard model, but asking them directly might be all it takes.
Edit:
Just as an aside, I’ve also tried to get a bit more attention on the VideoAMP outside of our usual circles.
Over the years I shared info, demo videos, and wiki links with Bob from RetroRGB, hoping he or one of his contributors might give it a look.
We talked about:
  • How the VideoAMP acts like a “UMSA on steroids” with SCART, VGA passthrough, audio input, sync filtering, and even GunCon support.
  • The usefulness of features like the built-in RGBHV to RGBS switch and the dual-output on the small Pro run.
  • How it connects to the wider CRT PC workflow, including CRT EmuDrivers, GroovyMAME, and other CRT focused distributions.
Bob was always polite and said he was really busy, and even mentioned passing it along to his Linux and MAME contact Dan who could better cover it.
So it is not that there was disinterest, but more that it never quite fit into his usual coverage focus, which makes sense given how niche CRT and PC setups can be.
I only bring this up to underline that I did try to push the VideoAMP into more mainstream visibility, but at the end of the day it mostly remains something shared within the PC CRT setups.
« Last Edit: September 04, 2025, 10:38:05 am by Rion »
Zebidee
  • Trade Count: (+9)
  • Online Online
Thank you. This explains a lot. The question about whether VideoAMP supports multiple outputs has been kicked around on BYOAC before, but never really answered properly.
I bought a VideoAMP v3.3 a couple of years ago, mostly for the EDID feature (forcing the GPU into 240p). However, I never got around testing for various reasons/excuses, including: my available PCs already run CRT_emulator so no driving need, GreenAntz transcoder development, TV repair/modding, and serious injury.
Anyway, I think VideoAMP is a great thing, and dual output widens it's appeal and usefulness.
Right now I have two CRT TVs, a component TV (Sony flat 20") and a modded dual RGB SCART/VGA input TV (JVC curved 20"). I'd love to be able to test them with VideoAMP, both running the same output simultaneously. I've added a pic below as a teaser.
This is also a very good feature.
I have managed to get GreenAntz auto-detecting composite sync input. It works great when csync is the only input. No need for a switch.
However CRT_emulator, when generating composite sync, does not switch off the vertical sync output! These "ghost" signals overwhelm the XNOR logic, creating an inverted vertical sync pulse. This problem affects all the transcoders I have tested it with (not just GreenAntz), it seems to affect all XNOR-based logic Csync. So the vertical sync still needs to be "blanked" when using CRT_emudriver Csync, thus a manual switch is still useful.
This might just be a problem with my setup (Win7, HD6450), so interested if this problem (vertical sync still output when in csync mode) is universal or just affecting me. I posted about it here, but only heard crickets chirping. Maybe I should just ask Calamity directly.
Great idea. Link?
IMO these features should be in the standard model. Is there some reason to exclude them, like cost?
We talked about:
Thanks again. I agree with these points and none of it really surprises me. VideoAMP is great, but you need to have a driving reason to use it. He gave some valuable feedback though, and all those points you listed are good ones. Partly mirroring Bob's comments, I feel that:
  • The Csync switch is essential.
  • Boosting video output to support two outputs simultaneously would greatly improve the appeal and "need" for VideoAMP.
  • A better understanding of how people would likely use VideoAMP in their PC/CRT/arcade/retrogaming setups is a good thing.
I have a few ideas and insights that could help njz3 and Bandicoot with their development. For example, how to boost the THS7375 outputs, and/or tweaking the outputs for different situations (e.g. output to two arcade monitors vs to just one TV). I might also be able to help with the Csync.
Calamity
  • Moderator
  • Last login:Today at 01:14:24 pm
  • Quote me with care
Sorry, I probably missed that or got me in the middle of some extra busy period. AMD's native c-sync is barely used by a few users as far as I know. I found it problematic to setup. E.g. if things don't go well it's hard to tell if the lack of sync is caused by c-sync or something else. If things break eventually and you need to do some configuration, you'll be back to separated sync without the proper wires. If you want to dual boot on Linux, no c-sync there. Etc. That's why I find a much better solution to handle c-sync externally.
Anyway, it's interesting what you mention of vertical sync not being turn off. I didn't know that. That's probably because it was assumed that v-sync wouldn't be wired. In fact that's how I connect it to my BVM, leaving the vertical bnc disconnected.
These are things worth investigating, having the right equipment, skills and time.
Steps to create a log:
Calamity
  • Moderator
I think VideoAMP is fantastic as it solves several issues at once that no other device combines: amplification + detection + edid emulation.
The only thing I missed in the test unit that njz3 gently sent me is amplification for the vga passthrough. I don't know if this was included in later versions, but looked like great addition for my use case.
The usefulness of hardware EDID emulation as an alternative to software based custom video is way more questionable, but that's another topic.
It was also suggested to provide support for VideoAMP through Switchres, which I really would like, if only I had the time.
njz3
  • Last login:March 26, 2026, 05:38:43 am
Hi,
Rion ping me to jump to this topic and answer about the simultaneous output feature.
The "standard" board has only a single THS7375 (gain ~x5) and there are 3 pots directly placed on the RGB lines of the amplifier.
Then, we added different impedances to the traces routed to each respective type of output (VGA, Scart, or RGBS) so that the final output amplitude match what is expected by the load.
For example, the VGA and Scart outputs have ~200ohm so that, when you plugged a 75ohm load, the final amplitude of the output signal is matching the expected 0 .. 0.7V range (you can actually boost a little bit the output signal to 110% of the input, sometime that can help).
If you plugged VGA and Scart outputs simultaneously, they will share the same video smplifier THS7375+3x pots, but then you have 2x75ohm load, dividing the output amplitude by 2x.
The "Pro" board has 3x THS7375, each output type has its own amplifier and get a separate output impedance.
I kept the 3 RGB pots only to tune the gains for the RGBS output (arcade monitor). VGA and Scart outputs have fixed impedance to get 1:1 amplitude with the VGA input.
Because it adds 2x THS7375, I cannot maintain the same price as the standard board (each chip already add ~2€ to the BOM + increased manufacturing costs/time).
At the end, the board price would be globally more expensive (+10€) while not everybody is interested by having simultaneous outputs.
I did a small batch of "Pro" boards, so if people wants they can ask me to get one.
Lately, I spent most of my time finalizing the jamma low-latency add-on for the videoamp (JammaMia board), so the VideoAMP design is almost frozen since a year or more.
We still welcome request for changes, provided they are simple enough to not "revolutionize" the board.
Zebidee
  • Trade Count: (+9)
  • Online Online
Hi njz3  8)
A reasonable approach to sharing a single amp - but your impedance matching is gone and still only one output at a time.
I imagine that the video output quality is improved as well, even for a single output - I'd pay a little extra for that alone. So I may just have to get one from you!
I know just how you feel   ::)  Regardless, here are my suggestions (a little long, sorry).
I believe you can reduce the number of THS7375 amps required. Maybe just two are needed. The datasheet states in many places that the THS7375 can support two 75R outputs simultaneously. You'll just need a few more caps and resistors.
[REDACTED]
Hope this help(ed). Make a local copy if you think this may be useful. I am aware of sensitivities and may delete all this in a week or two to save it being "harvested" by unwelcome players.
« Last Edit: September 12, 2025, 05:16:11 pm by Zebidee »
Zebidee
  • Trade Count: (+9)
  • Online Online
So, I went and did it. Then I took a video!
Using the VideoAMP v3.3, I took video outputs from the VGA passthru and SCART heads.
  • The VGA output (via VGA M-M cable and GreenAntz v1.94 RGB-YPbPr transcoder) goes to Sony CRT TV with component inputs
  • The SCART output (via home-brewed VGA-SCART cable) goes to a recently RGB-modded JVC
Even though VideoAMP v3.3 does not technically support 2x outputs, the picture looks great.
The Sony/component TV looks full, very sharp picture and colours clear and strong. Obviously the GreenAntz has its own internal video amp (THS7374) with the forementioned DC-bias voltage referencing of outputs, which means it will boost the signal even if the inputs are a bit low. The colours may actually be a little stronger than usual.
The JVC/RGB TV looks great too, colours clear and bright. The picture is perhaps slightly less sharp and bright, very slightly, but difficult to notice unless you hot-swap it back to single video output. EDIT: the sharpness and brightness came back fully after some minor adjustment to the color and brightness via normal TV menu.
Why? The JVC likes lower input voltage anyway, and I built 68R resistors into the RGB inputs to bring voltage down to the 0.5vpp it prefers (the JVC's jungle RGB input pins are internal, not standard for external input). These extra 68R resistors on the JVC's RGB may affect the "balance" of outputs from the VideoAMP, giving the GreenAntz/Sony a slightly larger "share" than the JVC. This explains why the Sony is slightly brighter. The two video outputs look great next to each other anyway. Any video output "balance" affects are small, very hard to discern, probably indistinguishable if the the JVC did not have those 68R resistors. The issue should disappear with VideoAMP "Pro" v.5 as it uses separate amps on the outputs.
I call this a success!
Some further explanation of the SCART:
I don't have a SCART-SCART cable, so improvised and used a VGA-SCART (now SCART-VGA) I already have, but in reverse. The VGA then connects to an alternate input I'd already prepared for the JVC TV.
The VGA-SCART cable is one I "rolled" myself years ago. It is extremely simple, all the connections are straight passthroughs, no resistors except a 150R on the blanking. It was designed for use as VGA to SCART, but works just as well for SCART to VGA! I had to swap the sync from pin 20 to pin 19 to match SCART-OUT pinout, but otherwise everything the same. Swapping the sync pins was super-easy because I build my SCART cables using female crimps and slide these onto the flat blades or pins used in SCART headers.
VideoAMP v3.3 does not support Csync input, which makes hot-swapping the unforgiving JVC back to single video output configuration potentially complicated. The JVC accepts pure csync input only, no "smushy" sync from twisting H&V together. I'd have to exit games, swap around displays and reset CRT_emudriver to Csync.
To completely bypass this potential sync-swap drama, I used one of Buttersoft's csync 15khz protection dongles. H+V IN, Csync OUT. Very useful device. Even though it is not used in the final setup, it helps occasionally for troubleshooting, so I included it in the pic below. The dongle is wrapped in paper tape as the 3D-printed enclosure falls apart after a while! Poked holes for the LEDs. I also needed two VGA gender-changers to match my cables on this occasion. Gender changers are attached in the pic.
« Last Edit: September 08, 2025, 10:03:45 am by Zebidee »
Zebidee
  • Trade Count: (+9)
  • Online Online
Oh, truly sorry, I really don't expect you to read all my posts and respond personally. Rather I was surprised that nobody responded at all, lol! I'm sure you are busy enough already. My own bad, posted on the main GreenAntz thread, so it was a bit buried. I should put up a new topic on the GM forum branch. Thank you for responding.
Even so, I'd argue that the issue must affect a fairly reasonable number of people, at different times, even if they don't understand it. If you are outputting to a CRT TV then an option for native c-sync output is better than smushy sync (twisting H+V wires) or some external device, like an extron, or a csync circuit built into a SCART header (advanced!). JPACs invisibly solved the problem for arcade monitor users (you need the JPAC for the JAMMA interface anyway), but not for TV users.
Yes - when using Csync, disconnecting the Vsync, to avoid random interference, seems a sensible precaution. I've given such generic advice many times before. With your BVM & BNCs you'll probably never notice the vsync issue. For my own part, I was mostly using Buttersoft's VGA dongle (outputs csync with no vsync) when testing H+Vsync vs Csync autoswitching on GreenAntz, so I missed it for a long time too.
For me, the issue became obvious when I was using native csync from CRT_emulator for the JVC TV RGB mod, and swapping back to the GreenAntz/Sony TV for troubleshooting. The GreenAntz lost sync! At first I thought I'd done something wrong, or some extreme interference on the Vsync wire. Only after hooking up the oscilloscope did I realise that it was more than just random interference, which shouldn't normally bother GreenAntz, but rather a full Vsync signal.
The point I trying to highlight, and you've already mentioned it, is that there are many different circumstances: sometimes we want Vsync connected, sometimes not, but it is not always easy to disconnect like a BNC. You can't just pull the V wire out of the VGA cable, or clip off the pins, or haul out and plug-in a different monitor. At first my only solution was going back to an older GreenAntz unit with a sync switch, until I figured to just "blank" (pull high) the GreenAntz Vsync signal with a wire (really just another kind of switch). Not everyone has those options.
Take SCART CRT TVs, for example. Probably 90% of CRT TVs will work OK with raw smushy sync (twisted wires). Problem with smushy sync is that, during the vertical sync interval, it doesn't invert certain pulses and completely loses many/most of the timing and information pulses (this is also where data like teletext lives!). Even so, most CRT TVs are clever (a better word maybe is "forgiving") enough to deal with this and give you a clear picture anyway. Affects vary from model to model, but many TVs will show a telltale little zigzag near the top of the screen. Anyway, if it works for you, and you're OK with the limitations, twisting H+V together and running that through a resistor is OK. Heck, you don't even need the resistor much of the time.
However, if you are fussy, or have a TV that is fussy, you may need to run with "native csync" and physically disconnect that Vsync line. The only other alternative is to run it through some external device (Buttersoft's convenient dongle to the rescue!). Never say never, but it is something I prefer to avoid, at least for any kind of long-term arrangement.
With a SCART or VGA cable input, disconnecting Vsync can be a lot more difficult than a BNC terminal. If you have a soldered cable, it could be very messy or even impossible. This is one of the reasons I make different VGA-SCART cables for different occasions (with/without resistors, Vsync plugs, auto AV-switching, external power input, audio, for example).
It's also a reason why I prefer to use crimp terminals on the SCART pins - no soldering, more flexible.
Back to the current example, this JVC TV is one of those 10% of TVs that is very fussy about sync! It demands good clean csync. Right vpp levels and no vertical sync weirdness. So I enabled Csync with CRT_emulator and disconnected the Vsync wire. In this instance I just pulled it off and re-crimped the Csync wire. Not a big deal, but no way back without soldering or re-crimping. On some other occasions I've made connectors using dupont (arduino) wires to make reversal easier.
Many of these situational dramas could be avoided if Vsync switched off when Csync is enabled. Most of the time I'd be happy to leave the Vsync wire connected so long as there is no signal on it.
njz3
Hi Zebidee,
The "secret sauce" is to AC couple the inputs (put 0.1uF caps in series) and add "pullup" resistors from voltage supply (Vs).
.. snipped your precious explanations that for sure I will save ...
First an introduction: Bandicoot and I are not professional electronics engineers. Worth pointing out that what we came with is purely done based on example (manufacturer datasheets), trial and errors.
We are simply two hobbyists that were trying to solve minor issues we have seen with other existing solutions, specifically the fact that no solution provides VGA input monitor detection. For arcade cabinets, there are known solutions like jammaSD, jpac or ultimarc amplifier, and maybe a few other solutions that I don't know of. For TV with RGB Scart inputs, there are UMSA and many DIY solutions which offers more or less the same level of functionalities. The VideoAMP was only a way to "unify" all those functionalities in a single board.
Regarding AC operation mode of the THS: we actually use the DC input/output mode of operation with 5VDC power, as explained in the datasheet p.21, figure 52 p.24 and described on the schematics of the evaluation board Figure 55 p.29 when you set it in DC operation.
We tried the THS7374 first (which is what almost everybody in our community use), and also I remember asking myself whether to use decoupling input (AC input operation). We picked the DC mode because it was simple and does not require noise rejection or any EMC filtering (see p22 about "hum" 50/60Hz noise rejection in AC mode) that might filter the video signal, loosing the "quality" of the edges that you can get from a purely RGB signal. The result was so good compared to the THS7374 that we kept the solution we have tried.
Please understand that I really don't know much about VideoAMP specifically either, except what I've been told and what I can physically see on the unit (v3.3) I have! I see the THS7375 has a couple of bypass caps for the Vs, but that is all. In fact I am just assuming this TSSOP-14 IC I've been looking at is a THS7375 (the numbers have been scratched off).
You are right, the caps are mainly for voltage input and filtering of sync signals.
Hope this helps. Make a local copy if you think this may be useful. I am aware of sensitivities and may delete all this in a week or two to save it being "harvested" by unwelcome players.
Ok, will do.
I can send one "Pro" board to you if you want (I have a few built available) at same price as a standard one.
If we could produce 1000 boards in a single batch, then the price decrease on the BOM would be so high that having 3x THS in DC mode, instead of 2x in AC mode would not even be a question ;-)
So far (and even if I try to make it more PCB assembly friendly), we only buy components by 10x or 20x and each board is still partially assembled by hand which takes time.
« Last Edit: September 09, 2025, 08:49:36 am by njz3 »
Zebidee
  • Trade Count: (+9)
  • Online Online
Thank you for that njz3. You and Bandicoot are much like me then. If there's no solution, then you'll make one! The best part about this hobby is learning as you go :D
I do have a general science & technology (including computers & gaming) background going back a long way, but that is mostly high-level stuff, some programming and data work, not hard technical or "real" electronics. More about understanding people, research, ideas and words.
So, much of my real electronics knowledge comes from what I've learned "hands on" with my arcade/retrogaming hobbies rather than years at school or in a technical role.
... We picked the DC mode because it was simple and does not require noise rejection or any EMC filtering (see p22 about "hum" 50/60Hz noise rejection in AC mode) that might filter the video signal, loosing the "quality" of the edges that you can get from a purely RGB signal. ...
The choice of AC or DC input mode for the amp is obviously whatever does the job, works best for you. FWIW A/V industry convention for devices is AC-coupled inputs and DC-coupled outputs. This is convention, not rule, and there are many exceptions (e.g. battery powered devices with AC-coupled outputs).
DC mode is simpler, and seen more commonly in our hobby, but AC coupling inputs only requires a 100nF (0.1uF) cap and a pullup resistor for each RGB line.
[REDACTED]
May every day be another wonderful secret!
Peace
PS - I'll PM you soon about the VideoAMP Pro v5!
« Last Edit: September 12, 2025, 05:21:08 pm by Zebidee »
Rion
  • 240p, 480i
Great idea. Link?
Sorry for the late reply.
Here is the link https://github.com/Redemp/VideoAmp_wiki/wiki
Trnzaddict
  • Last login:September 21, 2025, 10:48:29 am
I have a question myself.
One of the reasons I lost interest in running CRTEmudriver on my CRT was because Component looked too sharp and many games relying on composite blending did not look right.
At the time a few years ago, I was told that Emudriver will only work through component via a VGA-Component transcoder. Will never work through composite.
With this other transcoder mentioned in this thread, can we get Emudriver to output all timings and resolutions through composite finally? This would open up so many more CRT's to running an Emudriver PC as finding SD sets with component input is becoming harder and harder to find. So many nice sets I find on FB marketplace but they lack component, but have Compsite.
Zebidee
  • Trade Count: (+9)
  • Online Online
Hi, you raise a good question.
It is easy to confuse "composite sync" with "composite video". The latter includes sync + video (luma + chroma) signals, all on one cable.
GreenAntz transcoders do RGB (VGA or SCART) to component/YPbPr, not composite video. VideoAMP is not a transcoder.
However, there are some hardware options out there already.
Wakabavideo, who sells on ebay, makes a "RGB SCART to NTSC S-video and composite transcoder/encoder". You would also need to make or buy a VGA-SCART cable similar to mine. I think I've seen a VGA-NTSC version before, but can't find it online right now. Maybe you could ask him directly.
https://www.ebay.com.au/itm/174578156353
An alternative to VGA-SCART cable is an UMSA + standard SCART-SCART (male/male) cable.
Other than that, I could suggest a modded GBS-8200 (+ variants). These are on Aliexpress etc., and I see that some of them come pre-modded. More expensive but also more flexible. Interesting bit of tech, but I've never used one myself. From reports I've heard, it "does the job". That may be good enough.
Cheaper options? Consider adjusting the "sharp" settings of your TV. Models vary, but I find that this generally blurs RGB or component signals somewhat. I usually set it to zero, or close to zero, but perhaps you could try setting it to max for a composite video effect. You may need to access service mode.
If you are OK with a little soldering, component-modding TVs is often easier than RGB modding. I've already done some threads on this.
For all of the above, you would use CRT_emulator or similar (maybe VideoAMP!) first to get the right video modes. That is what they do  :notworthy:  Then you need the transcoder. The CRT_emulator setup is identical regardless of final colour signal format (as demonstrated by the video above).
I originally listed some things to AVOID, but this post is long enough already :)
« Last Edit: September 22, 2025, 12:33:15 am by Zebidee »
Rion
  • 240p, 480i
Short answer: yes - you can get CRT Emudriver timings out over composite or S-Video by adding an RGB→NTSC/PAL encoder (not just an RGB→YPbPr transcoder).
What to use:
1) A composite/S-Video encoder that accepts PC RGBHV
   • Two proven options:
     - Antonio Villena’s VGA → Composite/S-Video (with sync combiner) - made to take H+V from a PC and internally combine to c-sync
     - wakabavideo’s "RGB VGA → NTSC S-Video & Composite" transcoder/encoder - also accepts RGBHV and includes a sync combiner.
2) Real 15 kHz modes from the PC
   • Use CRT Emudriver/Switchres to output 240p/480i (NTSC) or 288p/576i (PAL)
   • You will get the classic composite blending artifacts those games expected (dot-crawl, cross-color), which is the goal.
3) SCART-route alternative
   • wakabavideo’s SCART → S-Video/Composite encoder also works; feed it with a proper VGA→SCART, VideoAMPUMSA or a good cable. Functionally the same end result.
4) What not to expect
   • RGB→YPbPr component transcoders do not make composite or S-Video.
   • Scalers or scan-converters (for example, GBS lines) can work but add processing and do not target native composite artifacts.
Bottom line: If you miss how composite looked (and blended), run 15 kHz from your PC and feed an encoder like Antonio’s or wakabavideo’s VGA unit. That opens up all those nice composite-only TVs you are finding.
Also worth noting for expectations: there is a quality difference between encoder chip families. See the AD723 vs CXA2075 notes in the linked write-up below. For VGA→composite/S-Video, the AD723-based approach often presents a cleaner, more stable result, while CXA2075 can behave a bit differently. Choose the one that suits the look you want.
AD723 vs. CXA2075 – Why the AD723 Can Look Better for VGA → Composite/S-Video
Edit:
Forgot the link to wakabavideo’s - RGB VGA to NTSC S-video and composite transcoder/encoder
It's out of stock right now.
« Last Edit: September 22, 2025, 08:44:09 am by Rion »
Rion
  • 240p, 480i
I agree with your role breakdown - GreenAntz = RGB↔YPbPr transcoder and VideoAMP = amp or switch, not a composite encoder. One useful clarification for readers:
1) "Composite sync" is not "composite video."
C-sync is only the sync line. Composite video is luma + chroma + sync on a single conductor.
2) Two PC-friendly VGA encoders with built-in sync combiners
Both of these accept a regular PC RGBHV signal, combine H+V to c-sync internally, and output S-Video and Composite.
Antonio Villena’s VGA → Composite/S-Video (sync-combiner variant)
3) SCART-route option
If someone prefers SCART in the chain, wakabavideo’s SCART → S-Video/Composite encoder also works. Feed it with a proper VGA→SCART, VideoAMPUMSA or a good cable.
4) Timings still matter
Regardless of the encoder, the PC must output true 15 kHz modes (240p/480i NTSC or 288p/576i PAL) via CRT Emudriver or via Linux with the 15khz Kernel patches.
5) Encoder families differ in look
There are quality and behavior differences between encoder chip families. See this write-up for context on AD723 vs CXA2075 and why AD723-type designs can be a better fit for VGA → composite/S-Video in many cases:
AD723 vs CXA2075 - Why the AD723 Can Look Better for VGA → Composite/S-Video
« Last Edit: September 22, 2025, 09:37:41 am by Rion »
Zebidee
  • Trade Count: (+9)
  • Online Online
Thanks Rion for clarifying and adding those links. Silly me forgot to mention Antonio's transcoder! Given it is the original thread topic and all.
Ahhh, Wakaba's NTSC transcoder is out-of-stock, must be why I couldn't find it when searching ebay before.
