Author Topic: Nanao MS9 with Retropie and Jpac  (Read 11129 times)
Ericthegreat
  • Last login:July 29, 2025, 02:13:12 am
« on: July 21, 2025, 05:08:00 pm »
Sorry if this is the wrong place, but anyone know the correct boot config for a pi 5 with retropie plugged into a jpac?
buttersoft
  • Last login:Yesterday at 07:03:42 pm
  • Is running at 15kHz
Re: Nanao MS9 with Retropie and Jpac
« Reply #1 on: July 22, 2025, 05:58:07 am »
Assuming you had a bare Pi5 (because i'm not sure about retropie in particular or RGBhats)... I was messing around for the first time recently and found they'd just updated the... method of selecting video modes on boot, i guess you call it. The docs were/are incomplete, especially around TV modes.
https://forums.raspberrypi.com/viewtopic.php?t=374305#p2250009
I managed to get 480i on boot by using an EDID file. You may even need to replicate this method to get 480p too, if that is your aim. The system may not change to the mode you specify until the desktop, but i think the boot process itself is at 480p.
PM me if you want the EDID files from that thread, i think the links are dead. You can also burn the EDID file to a dongle like one of these
https://www.aliexpress.com/item/1005007385743517.html?spm=a2g0o.productlist.main.18.2435N9k5N9k5Uw&algo_pvid=53e476d1-be20-40da-ab36-987e3d988af3&algo_exp_id=53e476d1-be20-40da-ab36-987e3d988af3-17&pdp_ext_f=%7B%22order%22%3A%2268%22%2C%22eval%22%3A%221%22%7D&pdp_npi=4%40dis%21AUD%2119.98%2111.99%21%21%2191.99%2155.20%21%40210318c317531783993676029e9684%2112000040530984044%21sea%21AU%21188447758%21X&curPageLogUid=rosIQDIEHdGs&utparam-url=scene%3Asearch%7Cquery_from%3A
Doesn't matter which one you buy, you can just overwrite it using ToastyX's EDID writer - https://www.monitortests.com/forum/Thread-EDID-DisplayID-Writer
« Last Edit: July 22, 2025, 06:30:11 am by buttersoft »
Ericthegreat
« Reply #2 on: July 22, 2025, 05:39:01 pm »
Do you have the 15khz edid (240p)
buttersoft
« Reply #3 on: July 22, 2025, 06:54:09 pm »
Sure. I may as well upload a few at once. Note that the 240P one is actually at 640x240p as i could not get 320x to work. With emulation you should be able to integer scale the image.
Ericthegreat
« Reply #4 on: July 22, 2025, 07:27:34 pm »
Thank you I'll try it, I have a feeling it's my HDMI to VGA adapter though, gonna test an active one.
buttersoft
« Reply #5 on: July 22, 2025, 07:39:25 pm »
i've found the Ugreen ones to be the best for the price. They work well for 15kHz, but also right up to 1080p. And the audio is good also.
https://www.aliexpress.com/item/4001289385303.html?spm=a2g0o.order_list.order_list_main.5.7ce91802f9EnLm
Ericthegreat
« Reply #6 on: July 22, 2025, 08:30:40 pm »
One will be here in the morning.
Ericthegreat
« Reply #7 on: July 25, 2025, 05:07:54 am »
Yep this+edid worked, emulation station text is really blurry though.
buttersoft
« Reply #8 on: July 25, 2025, 08:27:17 pm »
Great to hear it worked. At 240p i'm not surprised text in a utility is a little imperfect. As long as you have 240p so your games work properly. With a reminder that many arcade games weren't 240p, especially CPS1/2 at 384x224p.
