Author Topic: NEC Monitor. What model works for a Console Cabinet.  (Read 1867 times)
gonzo90017
« on: March 08, 2004, 02:10:04 pm »
I want to purchase an NEC monitor for my cabinet. But I heard only the older multisync models work. So which ones are they? I mean what model numbers? Or what should I ask to make sure it's compatible? Which NEC monitor model is best for consoles?
teetu
  • Last login:January 17, 2016, 03:29:31 pm
Re:NEC Monitor. What model works for a Console Cabinet.
« Reply #1 on: March 11, 2004, 11:22:11 pm »
I think the original Multisync and Multisync II.
I know the NEC Multisync 3D can do 15khz, but it's hard to come by these days.
Sorry I don't have a definate answer, but it's at least a start!
gonzo90017
« Reply #2 on: March 12, 2004, 10:54:05 am »
Thank's for the reply. I was starting to think nobody knew. By the way. I just got my hands on a Mulisync 3D. It's really hard to find the original Multisync unless you know the model #. When you search for them you get alot of results since NEC still makes that model However these are the newer ones that work above 60Hz.
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
Curls in the squat rack !?!?!
OSCAR
    • Oscar Controls
« Reply #4 on: March 12, 2004, 07:40:08 pm »
Here is a compiled list of pc monitors suitable for use as a std res arcade monitor:
http://www.ionpool.net/arcade/tech/monitor_test_bench.pdf
Note that there are also the larger NEC 'presentation'  monitors that will also have a hor sync range of 15 - 31/35kHz, so these sync right up to just about any arcade pcb that I'm familiar with.  I have a 26" NEC that I can connect a jamma board to without any problems at all.  My brother has a 32" NEC that is the same as mine only larger, but anything that large would just be obscene for use in a MAME cab, unless you are building a showcase style...  :)
