Author Topic: Which processor is best for MAME?  (Read 4892 times)
MarsMan2
  • Last login:November 26, 2024, 04:30:23 am
« on: November 20, 2024, 08:37:41 am »
In my old MAME PC, I have an i3-2120 and could upgrade to an i7-3770s.
Would there be a significant performance improvement with MAME if I did this?
I ask this because the i3 actually has a higher base clock speed than the i7 in this case.
I have since purchased this 3770s processor but not installed.
The 2120 runs at base frequency 3.3Ghz with 128kb L1 and 512kb L2 cache. There is no turbo boost.
The 3770s runs base frequency 3.1Gz with 256kb L1 and 1Mb L2 cache. It can turbo to 3.9Ghz on one core.
So the lower spec processor has a HIGHER base frequency.
See comparison here:
https://www.cpu-world.com/Compare/502/Intel_Core_i3_i3-2120_vs_Intel_Core_i7_i7-3770S.html
Anybody?
« Last Edit: November 25, 2024, 10:56:45 am by MarsMan2 »
Endprodukt
  • Last login:Today at 07:39:16 am
Re: Which processor is best for MAME?
« Reply #1 on: November 24, 2024, 01:56:10 am »
It only matters when you care about playing specific 3D games. Some are very demanding like gauntlet legends.
The turbo will make a difference but not significantly. You see the biggest improvement in frame delay if you use that.
makya
  • Last login:March 22, 2026, 10:57:48 am
« Reply #2 on: November 24, 2024, 02:24:54 pm »
Well I would use the i7 because it's rated significantly higher in single thread performance
MarsMan2
« Reply #3 on: November 25, 2024, 10:55:56 am »
@makya, thanks for your post. This is the entire crux of my question.
The i7 is SLOWER than the i3 at single core base frequency.
« Last Edit: November 25, 2024, 10:57:34 am by MarsMan2 »
makya
« Reply #4 on: November 25, 2024, 11:01:09 am »
It runs at lower frequency but why do you care, as long as it performs better?
MarsMan2
« Reply #5 on: November 26, 2024, 04:30:23 am »
How can a processor 'perform better' running at a slower frequency compared to one running at a faster frequency?
Doesn't MAME run on a single core? Isn't the base frequency the crucial variable for optimal performance from MAME?
makya
« Reply #6 on: November 26, 2024, 06:00:50 pm »
What matters is single thread performance and one given processor can run better at a lower freq than another one, because they are not based on the exact same technology.
haynor666
  • Last login:January 09, 2026, 02:33:07 pm
  • retro maniac
« Reply #7 on: December 15, 2024, 03:15:29 pm »
You could look at https://www.cpubenchmark.net/singleThread.html#desktop-thread
Basically higher score means better performance in MAME.
« Last Edit: December 15, 2024, 03:17:40 pm by haynor666 »
