Author Topic: Faulty IR bar? Or Aimtrak?  (Read 4553 times)
breathsavers
  • Last login:September 27, 2024, 03:14:01 pm
« on: September 26, 2024, 11:31:48 pm »
Hey everyone - I'm having trouble with my Aimtrak. It seemed to work fine at one point, but now on both my PC's, I can't get any IR signal showing. I think maybe the gun or IR bar is malfunctioning? My Aimtrak does show as connected in the Aimtrak program, firmware 9.20, Device 1. When I click the trigger, the mouse clicks in the very bottom left of the screen no matter where I point the gun. When I try to calibrate, the screen flashes but it never registers any clicks. It has this same behavior on both PCs. Any ideas are appreciated!
lilshawn
  • Last login:March 08, 2026, 07:17:46 pm
Re: Faulty IR bar? Or Aimtrak?
« Reply #1 on: September 27, 2024, 09:36:41 am »
you can easily find out if your IR emitters are working by using your phones camera. the IR light will appear as a dim purple glow. depending on your camera and the filters in place on your camera, you may have to get up really close and be in a pretty dark room to see them. but this will verify if they are all functioning properly.
