Author Topic: How many amperes in 4 Ds  (Read 1583 times)
crashwg
« on: February 22, 2004, 06:57:47 am »
I want to hook up an electronic device, that normally runs on 4 D cell bateries, to power outlet.  What specificly shoul I look for when I go look for transformer (is that what ya call em?)?  I have a 6v 100ma that came from a gameboy (the original one) and it doesn't provide enough power.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Ken Layton
  • Guru
  • Technician
Re:How many amperes in 4 Ds
« Reply #1 on: February 22, 2004, 12:02:02 pm »
You'd probably want a wall adapter that can provide 6 volts DC at a minimum of 1 ampere.
hyiu
    • www
« Reply #2 on: February 24, 2004, 10:37:49 am »
I don't think you'll need 1 Amp....
most transformers... those AC -> DC ones are like
300mA or so....
have you tried to hook it up with a 6V 300mA transformer ??
ormaybe a 7.5V 300mA transformer ??
next step up should be around 800mA.....
what kind of equipment is that ??
some stuffs are more sensitive to different voltage / different amp... easier to burn out if given too much power....
Rocky
« Reply #3 on: February 28, 2004, 09:39:41 am »
The amperage rating on a transformer is the maxium current it can safely draw. If your equipment needs more current, it will draw it anyway causing your power transformer to overheat or burn up.
crashwg
« Reply #4 on: February 28, 2004, 03:57:49 pm »
 :P It's a baby swing lol, I'm not thinking it's all that sensative so I'll just see if I can find something in the 800ma - 1a range, that should do it.
Lemme say it again
GamingGreg
  • Last login:August 05, 2018, 06:04:30 pm
« Reply #5 on: March 01, 2004, 01:12:54 pm »
Just don't turbo charge that swing or things could get really ugly!   ;D
