Author Topic: Newbie, be gentle LOL WG D9200 Silver Strike Bowling Cables for monitor local  (Read 1297 times)
ScottSundevil
  • Last login:May 26, 2021, 05:49:09 pm
Does someone with a Silver Strike have a WG D9200 in it and could just snap a couple pics for me would be the easiest LOL
Update: Ok found where the degaus 2 wire goes and the 4 wire from neck to main board.
So questions now are where does the 3 wire from neck board go (RGB on a 6plug) and the 6 color ribbon from main monitor board go??
Ok short version... I picked up a Silver Strike 2009 in pieces. Thankfully its all there I think. I have the computer booting to gameplay. So now its down to the monitor. Its all in one piece neck was not snapped but neck board and main board floating around in cabinet. Now, I have a couple of cables I cannot locate as to where they belong. And the large 4 wire from the neck is not "keyed" so I dont know what color is pin 1 on the board.
So that is question #1 As I am looking at the main board Pin 1 being to the left, does the blue or yellow go on Pin 1?
First wire is on the neck board as seen in attachment #1
Both the other 2 are on main monitor board. The 2 wire (red/black) there are two possible locations on the board one along the very bottom edge the other to the right of the neck and almost middle of board.
Looking at the schematic for the monitor I am wondering if I am missing a small board that those connect to? on the schematic it is called the "video sync interface board"
Thank you so much for any help!
« Last Edit: July 23, 2020, 08:11:42 pm by ScottSundevil »
