Author Topic: Router bit questions  (Read 10359 times)
vertexguy
  • ...but this one goes to 11.
« on: June 24, 2020, 11:14:08 pm »
This may seem obvious to pros but I'm wondering if there really is a significant difference between a flush trim bit and a straight bit
The only difference I see is the bearing on the flush trim.  My bearing is at the top by the router with the blades below it.  So wouldn't it behave the same as a straight trim bit if I lower the collar enough on the router to only have the blades on the bit below it, bypassing the bearing?
Wouldn't that work the same as a straight bit?
I'm hoping I dont have to buy yet another bit for routing my cp but dont want to take unnecessary risk if it's actually not the same.
« Last Edit: June 24, 2020, 11:16:04 pm by vertexguy »
jennifer
Re: Router bit questions
« Reply #1 on: June 25, 2020, 02:21:08 am »
« Last Edit: April 15, 2021, 09:40:14 am by jennifer »
vertexguy
« Reply #2 on: June 25, 2020, 02:39:03 am »
I just have a craftsman 9.5 amp fixed based hand router.
jennifer
« Reply #3 on: June 25, 2020, 03:10:44 am »
« Last Edit: April 15, 2021, 01:00:23 pm by jennifer »
Arroyo
  • Last login:May 25, 2026, 06:20:43 pm
  • Budgets are boring
« Reply #4 on: June 25, 2020, 11:30:39 am »
My two cents....the flush trim bit is designed to be used to ride the surface of either a straight edge or more often a template.  It’s mostly intended to be used for making copies of something, but can be used for straight edge cutting as well.
While it in principle is no different than a straight bit here’s why I think you should avoid using it as one.  The value of the flush trim bit is in the bearing.  It’s why most experienced wood workers have given me the guidance of using it to cut minimal amounts.  You want to protect the bearing from gumming up and if used to do heavy amounts of cutting it will increase the likelihood of that happening.  In addition the pattern bits are all 1/2” in diameter, whereas most straight bits are 3/8” (there are of course various other sizes).  Using the larger diameter means more material being cut away which means more resistance, heat, etc that can contribute to the wear and tear on the bit.  Using a 3/8” diameter means less material, less resistance and less heat, and no concern about protecting a bearing.
Having said all this, the bearings are replaceable (something I didn’t learn until more recently).  I have used the top bearing bit to cut A LOT of straight cuts.  I’ve since relied heavily on the track saw, it’s easier to setup and doesn’t remove as much material when cutting.
So yeah you can use it, but I’d start investing in things for their intended use, hence the straight bit where you can, and the pattern bit when you need to.  Hope that helps.
vertexguy
« Reply #5 on: June 25, 2020, 11:56:57 am »
Generally this makes sense to me, but now I'm confused about templating.  It sounds like I should be using at least 2 different bits for the process if done right?  IE If I had a jig / template of a joystick mount, I should use a straight bit to remove the bulk of the material in the middle and then a flush trim to get precise edges?  Is that the idea?
What about a mortising bit?  I read in someones post they recommended that for routing out joysticks.  Keep in mind though my router is fixed based so I don't think I can plunge cut.  Given that, I don't see the advantage for me over a straight bit in that scenario?
Arroyo
« Reply #6 on: June 25, 2020, 12:42:37 pm »
Yeah, although if you have a jig saw or something else that can remove the bulk of material that would be preferable.  I try and use the router for minimal cutting (it removes a lot of material).  If you have a lot of material to remove better to use another tool.  Having said that yes you can do as you suggested.
Mortising bits are great to handle a 90 degree angle inlay (removal of some but not all the material).  It would be easiest with a plunge base.  But the main idea is it creates 90deg corners, as a router bit would leave a rounded corner.
I only just started using a plunge base.  It’s really helpful for getting precise depth of cuts, but not a necessity to get things done.  If you have the ability to get one for your model router I’d say go for it.  But if you are just starting out maybe just learn how to use the static base and see what all you can do with it (it’s a lot).  Not sure if that answered your question?
bperkins01
« Reply #7 on: July 01, 2020, 01:23:58 pm »
I did a quick read through this thread - it sounds like you want to use your router bit as a saw..  its not a saw..
Pattern bits are for cleaning up cuts (from a saw typically) along a pattern (they have bearings)
Straight cut bits are typically used in plunge routers or on a router table to cut rabbets and dado's (groves)
Neither should be used to cut big pieces into smaller pieces..  Get a jig saw for that type of work
I did a lot of pattern bit routing here:  https://arcade-rescue.com/2018/05/27/lakeside-arcade-making-the-control-panel/
If you want to see it in action
  • Last login:Yesterday at 02:28:59 pm
« Reply #8 on: July 01, 2020, 01:27:12 pm »
 :stupid
Sorry. There is no emoji that says:
"I'm with the guy who knows his ---steaming pile of meadow muffin---."
I guess it is not as catchy.
