Author Topic: catver in mamewah  (Read 1860 times)
arizonacats
  • Last login:May 20, 2004, 08:03:06 pm
  • ...at least my cab works now...
catver in mamewah
« on: February 19, 2004, 02:07:46 pm »
Sorry to bring this topic up again, but I'm still having a little difficulty.
From the mamewah faq:
Q: How do I get MAMEWAH to show game category / genre info?
A: Use the CatVer.INI file. Set the 'CatVer Filename' from within 'Emulator Settings' > 'List Generation Settings'. Then refresh the games list.
1) Would this refresh of the games list automatically create custom lists and/or sort them or what should I be expecting?
I can't find the "CatVer Filename" option in Emulator Settings (or anywhere else).  I used the setup tool and added the catver.ini in there, but it doesn't do anything for me.  I can however create custom lists and filter them by category, so I assume mamewah can see the catver file?
2) Am I missing something in my mamewah setup that would prevent me from seeing the 'CatVer Filename' in my emulator settings?
Thanks for any help!
Re:catver in mamewah
« Reply #1 on: February 20, 2004, 07:06:22 am »
The FAQ is somewhat outdated (my fault) so it has changed slightly...the 'CatVer Filename' option has actually been removed.  All you need do is place catver.ini in your MAME root folder.  When you refresh the list the catver info will be available.
In answer to your Q's:
1) No.  All you should expect is to be able to see/use the categories to filter on in the 'Generate Custom List using Filters' menu.  Also, in the default layout, the current games category is displayed in the bottom right.
2) No, explained above.
You say you can filter by category, so really you have it working! :)
arizonacats
« Reply #2 on: February 20, 2004, 11:33:50 am »
Thanks Minwah, I'm glad I'm not crazy!  ;)
I noticed before I wrote this that I've only posted 18 times, and you have posted 1887 times... over 100 times more posts!  It's great that there are experienced BYOAC'ers like yourself who are willing to help out the new guys on the scene.  Thanks again for your help, and great job on Mamewah, I'm loving it!
« Reply #3 on: February 20, 2004, 12:01:28 pm »
No worries, glad you like it! :)
boarderguy41
  • Last login:August 05, 2004, 07:24:53 pm
« Reply #4 on: August 06, 2004, 02:04:14 pm »
ok im having the same problem now, and i just installed the new catver.ini file and now it wont even let me go into the "generate custom list using filters" menu. i press 1 and it doesnt do anything
« Reply #5 on: August 07, 2004, 08:40:58 am »
What List Generation Method are you using?  MAMEWAH will not let you into the filters menu, if it doesn't have anything to filter on.  Make sure you use a listinfo List Gen. Method (MAME v0.83 & previous), or a DAT File one.
