Author Topic: Power Supply Testing  (Read 3416 times)
heydude348
  • Last login:April 29, 2020, 10:48:01 am
« on: April 08, 2020, 06:48:57 pm »
How would I go about testing a power supply for a Golden Tee arcade.It's a Happ Control P/N 80-0002-10 Rev. H.S/N 0241156.115v in.5v/12v output.Which pins do I check voltage on? Thank you for your help.
mourix
  • Last login:August 07, 2026, 03:28:45 pm
Re: Power Supply Testing
« Reply #1 on: April 09, 2020, 01:00:02 pm »
I attached a photo from the Happ website. It shows all wire colors for the different voltages :D
heydude348
« Reply #2 on: April 17, 2020, 05:14:13 pm »
I just checked the voltage and they all appear to be on the money.Only thing I noticed the red leads showed a positive voltage while the blue,yellow and white showed in the negative on my meter. I put the black lead from my meter to the black center wires of the coupler.Im guessing they are all ground so no matter which one you place them on they will give you a ground reading?
