Author Topic: ipac2 mode switch to xinput via command line  (Read 3055 times)
bensonr2
  • Last login:February 15, 2020, 11:56:36 am
« on: January 16, 2020, 01:33:58 pm »
Has anyone figured out a way to force mode switch to xinput via command line?
I recently updated my ipac2 fw so I can enable mode switch.
If possible I would like to setup my mode switch automatically from LB.
I am halfway there. I can force kb mode by a command line to load a profile in the background in winipac which successfully forced it back to kb input if it is in another mode.
Can anyone see a way to do the same to force it to xinput?
gstav
  • Last login:October 06, 2025, 02:10:15 pm
    • forum.arcadecontrols.com/index.php/topic,157861.0.html
Re: ipac2 mode switch to xinput via command line
« Reply #1 on: September 07, 2022, 09:21:22 am »
Hi, I'm in the exact same situation. Did you found any solution for this bro?  :hissy:
"One coin to rule em' all"
nugarp
  • Last login:November 09, 2025, 11:22:06 pm
« Reply #2 on: September 09, 2022, 06:42:18 am »
Just use keyboard2xinput
Sent from my SM-G950U using Tapatalk
Wheel2XInput | HDRecoil | LeaderLamps | NetLauncher | Discord | Youtube
