Author Topic: TV is too deep...  (Read 1858 times)
maraxle
TV is too deep...
« on: February 11, 2004, 08:00:57 am »
Well, I've run into the first hitch in my cabinet building project.  My TV is too deep for the cabinet.  If I put it on a completely level shelf, it touches the plexiglas monitor shield and the back door.  Therefore, if I angle it at all (like how the original monitor was), it will have to stick out the back of the cabinet.  I shined a flashlight into the vents on the back of the TV to see if taking off the case would help any, but it only seems to give me about half an inch more to work with.  A smaller TV isn't really an option, as this is a 20-inch TV, and all of the 19-20 inch TVs that I've looked at are within half an inch of this one in depth.
So, what does everyone suggest?  Do I keep the TV on a level shelf, and have it practically touching the plexiglas, or do I angle it and have it sticking out the back?
Here's a picture of the cabinet:
« Last Edit: February 11, 2004, 08:02:30 am by maraxle »
menace
Re:TV is too deep...
« Reply #1 on: February 11, 2004, 08:38:46 am »
I think PO (paigeoliver) mentioned this in another thread--cut a hole in the back door and build a small box around where the yoke sticks out so that nothing can actually hit--then build another "bump" at the bottom so that when it rests on its back its still level--this way youy can have the monitor oriented the way it should be and you don't risk damaging the tube.
maraxle
« Reply #2 on: February 11, 2004, 10:19:52 pm »
Thanks!  That's probably what I'll do.  :)
eightbit
  • My cab is never done...
« Reply #3 on: February 16, 2004, 09:40:25 pm »
My gorf cabinet has a bump out like that as part of its origanel design.
