Author Topic: Boards on the Floor: RIP  (Read 44335 times)
  • Bitches love Centipede
« on: September 15, 2018, 02:30:41 pm »
Opened a dart hall. The walls are corrugated sheet metal. Needed to mount some steel tip boards. Ready-made stands cost too damn much for what you get. So BYO!
Step 1: Sketchup.
Step B: Cut some wood.
Step "time to stop counting": Paint said wood. I like Rustoleum's oil based Semi-gloss Black.
Time to start putting the pieces together. The frame is just 2x4s. The back board is 1/2" particle board wrapped in black felt, and secured to the frame with wood screws and finish washers (these little guys rock).
One mostly done.
Multiplied by a factor of four...
Added some of the scrap 1/2" plywood on the backs of the bases to keep the stands up against the crests of the sheet metal ridges. Also added some support braces to the bases.
Lowe's has the best cost effective solution I've found for dartboard lighting. These clip-on LED lamps work great.
The soft tip boards also got an upgrade to international color segments during this time...
A good friend of mine has a 48" printer that I put to good use for banners 'n ---steaming pile of meadow muffin---...
Here you can see the carpet oche for the soft tip boards. The distance from the oche to board surface for steel tip is 2 3/4" closer, hence the sticker oches on the floor for the steel tip boards. These stickers drove me nuts during the short time they were installed. I had to come up with another solution...
Finally! A decent use for LED T-molding!
But how? Internationally, raised oches are the norm for steel tip. But I didn't want to build bulky boxes. 3/4" particle board will work...
Four raised oches cut to width...
Then I cut them to length. All cuts were made with a router and flush trim bit. Cut the t-molding slots on the front edges. Ran wiring harnesses down the sides. Wrapped em up in carpet (was on sale at Menards for 27 cents a sq ft). And installed the t-molding.
While waiting on the slow boat from China, I threw some scrap LED strips in to see the effect...
The RGB strips and controllers showed up... But they failed to send me the power supplies I ordered...
Installed RGB LED strips on the backs of the stands. Secured the strips with hot glue (that 3M adhesive sucks).
Some soldering occurred...
Fancy...
Sourced some power supplies state side...
And BEHOLD! Boards on the floor!
Shoot well! :cheers:
« Last Edit: September 07, 2021, 02:21:57 pm by Nephasth »
%Bartop
  • Last login:September 24, 2026, 09:39:45 am
Re: Boards on the Floor: Steel Tip Dartboard Stands and Raised Oches
« Reply #1 on: September 15, 2018, 02:32:56 pm »
This is super cool.  Looks like a really fun place to hang out.
« Reply #2 on: September 15, 2018, 02:38:33 pm »
Freakin' sweet.
« Reply #3 on: September 15, 2018, 02:43:34 pm »
Nice! Looks pro.
Your hall is really coming together. Business must be good!
« Reply #4 on: September 15, 2018, 02:50:50 pm »
Neph OcheCinco
  • Last login:Yesterday at 05:03:35 pm
« Reply #5 on: October 03, 2018, 11:42:39 am »
So I'm contemplating hanging a dartboard outside now that it's not 105 degree everyday.  Original idea had been to strip down an Arachnid softtip machine to just the dartboard and hang it, but my wife wants steel tip.  Which ---smurfs--- up everything.
So, any thoughts on a steel tip board that can reasonably survive the elements?  Seems like everyone has the same $20 board.
It'll be underneath an overhand, so shouldn't get any direct rain but it's humid 24/7 here.  Maybe I just replace it every few months.
I also spent a lot of time at Lowe's (a lot of time) looking at ideas for backing.  Magically, every single machine they had in house to cut anything was broken, and my little fart box can't fit a 4x8 sheet of anything into it.  I looked at cork tiles but it would take a bunch of them (I'm covering 20 square feet).  Today I'm thinking about "garage foam board insulation" which is about $10 a sheet and I can cut it in the parking lot to cram it into my Toyota.  I could cover it with felt.... or just paint it black.
Just rambling here, I guess, but this thread got me wanting a dart's setup again.
« Reply #6 on: October 03, 2018, 12:17:33 pm »
I've used 3 different boards for leagues so far. The Unicorn Eclipse HD2s DO NOT hold up well. The wire backs out of the board over time.
So far these have held up extremely well in a bar environment: Viper Razorback
I also picked up a couple of Winmau Blade 5s for the dart hall. Very impressed with those so far, but not sure how they'd fair outside. I'll see if I'm still impressed with them after a season of leagues has been played.
%Bartop
« Reply #7 on: October 04, 2018, 11:06:41 pm »
Made some lamps.
Painted them Rustoleum Hammered Black.
Mounted to tables.
Wired lamp.
Ran outlet/usb charger and lamp wire through table leg.
Foot is hollow...
---steaming pile of meadow muffin--- image, but spliced lamp and outlet wires at a 3 pin molex connecter. Did the same to one end of a 12' flat extension cord.
Now each table has a charging station and overhead lighting. No more fluorescent lighting!
« Last Edit: October 05, 2018, 08:37:07 am by Nephasth »
%Bartop
« Reply #8 on: October 04, 2018, 11:23:32 pm »
Maybe I missed it but what are you doing here? Business? Private club? Game room?
« Reply #9 on: October 04, 2018, 11:46:56 pm »
Pretty much all of the above.
%Bartop
« Reply #10 on: October 04, 2018, 11:51:12 pm »
Wow you’re really surprising me how you’ve made this space look so pro.
I’m loving what I see here. Excellent work brother!  :cheers:
« Reply #11 on: October 06, 2018, 01:56:28 pm »
Thanks man!
Here you go Jim... A couple quick and dirty shots of the "game room" portion of the dart hall. Nothing fancy. Skeeball and Strata Bowling are the big earners in this corner.
%Bartop
« Reply #12 on: January 08, 2019, 01:49:24 pm »
After 3 months of heavy league use, the carpeted raised oches developed some "bubbles". I unwrapped them all, put down a bunch of carpet tape and re-wrapped them. No more bubbles and the carpet is nice n' tight for the new league season. Took about 20 mins per oche.
%Bartop
« Reply #13 on: January 08, 2019, 07:06:41 pm »
I wanna go to The Ocho one day
« Reply #14 on: January 08, 2019, 07:11:57 pm »
Definitely one of the best looking storage units to hang out in.  :lol j/k!!
« Reply #15 on: January 08, 2019, 08:57:50 pm »
I would love to stumble out of there one day.
« Reply #16 on: January 08, 2019, 10:31:51 pm »
It's come a really long way. I guess since my last update I've also built a riser podium for my desk, added stow-a-way tables to the back wall for snacks n crock pots n ---steaming pile of meadow muffin---, and some more LED accent lighting. Really wanting to expand into the unit behind me with another 6 boards. We'll see what 2019 brings! :cheers:
%Bartop
bperkins01
« Reply #17 on: January 09, 2019, 07:51:38 am »
Nice place you created!
I started playing darts right around the same time I started the design/build of my cabinet.
Here is my cabinet - which would never be used in a setting like yours.
https://bperkins.wordpress.com/2018/01/28/lakeside-arcade-dart-cabinet/
Which is part of the reason my cabinet is named 'Lakeside Arcade'  the game and dart cabinet in the same corner :)
Great work again - thanks for posting these.
JudgeRob
  • Last login:July 05, 2026, 07:12:25 pm
« Reply #18 on: January 11, 2019, 05:02:32 pm »
Sweet spot dude! Lighting looks great.
bperkins01
« Reply #19 on: January 11, 2019, 09:53:41 pm »
I'd love to go there..    :applaud:     I bet its no where near me  :(
« Reply #20 on: January 12, 2019, 01:13:37 am »
Thanks guys! Tonight was the first night of Spring Mixed Doubles. Fridays get pretty busy...
%Bartop
« Reply #21 on: February 21, 2019, 07:08:14 pm »
After months of use, they're getting a little worn. T-molding getting kicked out had become a common occurrence. So, time to upgrade!
Pics showing the carpet wearing on the corners...
I always hated seeing corner protectors on cabs... But they're exactly what I needed to keep the t-molding in place and carpet from wearing further.
Test fit...
---fudgesicle--- it. Run it.
I dig it.  :cheers:
%Bartop
  • Last login:September 15, 2026, 08:48:46 am
« Reply #22 on: February 21, 2019, 07:22:09 pm »
Slick!  That looks the business.  :cheers:
bperkins01
« Reply #23 on: February 21, 2019, 07:29:16 pm »
Nice work :)
« Reply #24 on: March 22, 2019, 03:28:24 pm »
Sold Johnny Mnemonic to fund most of a "mini expansion". Two more Radikal boards, some tables & chairs, room dividing curtains, couple of lights, some carpet work, and rearranging of the arcade games. I'm almost to a point of being happy with it all.
 :dunno
%Bartop
bperkins01
« Reply #25 on: March 22, 2019, 03:30:19 pm »
Outstanding!  :applaud:
« Reply #26 on: March 22, 2019, 05:35:12 pm »
Snazzy!  Looks really inviting. If i were a darts guy I'd totally be into this spot.  :cheers:
meltman
  • Last login:April 02, 2025, 11:06:11 am
  • Brilliant!
    • forum.arcadecontrols.com/index.php/topic,158544.0.html
    • My arcade gallery
« Reply #27 on: March 22, 2019, 06:26:19 pm »
SIIICCCKKKK.
I now need to build a dart board. Wow. Wowowowow.
« Reply #28 on: March 23, 2019, 11:32:40 am »
That looks fantastic!
Anywhere you could put up a few large screens dedicated to a leaderboard, shout outs, etc?
« Reply #29 on: March 23, 2019, 12:28:32 pm »
I have a 55" next to my desk/customer service counter. When there are no tournaments I run a slideshow of event flyers, various logos, and champion pics. During tournaments it displays the brackets (also found on each dartboard, but the big screen is easier for spectators and players with poor eye sight). During foosball season, it fulfills a third purpose. If I get to a point of ridiculous revenue, I may add some big screens above the boards... But I'm a cheap bastard.
« Last Edit: March 23, 2019, 12:30:12 pm by Nephasth »
%Bartop
Re: Boards on the Floor: And Also on the Walls
« Reply #30 on: April 12, 2019, 04:28:12 pm »
What to do with the ugly pipes?
Drink holders! The classic kind... Like tables... Or shelves... Yeah, drink shelves!
Not sure many of you would remember my game room back in the day, but I had an old mantle-turned-drink shelf in there, and it was awesome.
So the plan was to make something similar for this wall...
Basic form cut...
Forty-fived a corner and fancied up the edges...
Black Cherry...
Rattle can triple thick...
This sucker is held up with 3 1/4-20 bolts and t-nuts. Pretty ---smurfin---' stout.
Had some parts left over, so I made a second one. Found a break in the "blizzard" to route the edges OUTSIDE...
Held up the same way as the last one, 3 bolts and t-nuts...
Jigsaw work was done inside...
Same stain and semi-gloss polyurethane...
A couple of handsome drink shelves at...
%Bartop
« Reply #31 on: April 12, 2019, 04:43:40 pm »
Those look really nice.  Hard to imagine snow in April.
bperkins01
« Reply #32 on: April 12, 2019, 04:47:44 pm »
ok - how do i join this club -
I have my RVB darts..  I can score..
:P
« Last Edit: April 12, 2019, 06:05:21 pm by bperkins01 »
« Reply #33 on: April 12, 2019, 05:44:53 pm »
Find this door...
...and open it.
%Bartop
« Reply #34 on: April 12, 2019, 06:53:19 pm »
Those drink shelves are indeed handsome!  Nicely done.   :applaud:
The Oche looks like a cool place to hang out at!
bperkins01
« Reply #35 on: April 13, 2019, 08:49:11 am »
I found it!  - and CRAP!  - you are really far away..
Great place   :applaud:
« Reply #36 on: September 14, 2019, 07:29:00 pm »
Have I mentioned MikeA is the ---smurfing--- man?!
Sent from my LM-G710VM using Tapatalk
« Last Edit: September 14, 2019, 08:09:57 pm by Nephasth »
%Bartop
« Reply #37 on: September 14, 2019, 07:52:27 pm »
That’s a lot of plaques.
« Reply #38 on: September 14, 2019, 08:08:47 pm »
One Champion (picture plaques) and one MVP for each ADA League I've ran so far.
%Bartop
« Reply #39 on: September 15, 2019, 07:00:29 am »
I am glad everyone likes them. I learn something new with every batch I make. It is a fun project.
