Author Topic: Q: mounting the T-Stick in a CP  (Read 1486 times)
Felsir
  • Last login:July 09, 2025, 03:34:33 am
  • Creating cab artwork
    • Felsir's World
« on: February 06, 2004, 09:49:27 am »
I bought a set of T-Sticks and I'm quite happy with them, I tested the sticks in a cardboard test panel and I'm ready to build the sticks in my cab. So I was wondering what the best way is to mount the T-Stick on a CP?
A) The metal plate on top of the wood in de CP
B) The metal plate under the wood of the CP, the shaft through a small hole.
C) Other...
I figured the stick is quite short so case A would be the best for the 'most' stick. But this also means that you'd have to cut quite a hole in the wood. Also, the metal doesn't give the panel a nice flat look.
In case B, how thick would the CP be? The thickness of the CP would mean that the stick is shorter?
A search in this forum showed me that a lot of people use the T-Stick so I was wondering: how did you build the CP?
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
Re:Q: mounting the T-Stick in a CP
« Reply #1 on: February 06, 2004, 10:25:07 am »
1-1/8" hole(same as buttons) thru 3/4" panel
Screwed in from the bottom, 1/2" length woodscrews
It is a little short, but I dont mind it at all
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
« Reply #2 on: February 06, 2004, 12:04:08 pm »
I've done it both ways, and I like the metal plate on top, just because of the shaft length of the T-Stick.  Now that there are a variety of stick lengths and ball tops, I'll have to see which works best, but with the original shaft I think it's worth the effort to route a depression for the metal plate on top of the CP.
NoOne=NBA=
« Reply #3 on: February 06, 2004, 03:12:11 pm »
You basically answered your own question.
Which of the methods you described "feels right" to YOU?
