Author Topic: MAME CHD Question......  (Read 2923 times)
mike boss
« on: May 08, 2018, 09:45:36 pm »
I'm sure this is an easy question, but I can't find the info.
For MAME CHD files I know they are supposed to be in a folder with the same name as the ROM.
I thought in later versions of MAME you could simply add the CHD files to the ROM folder and they are not required to be in a folder.
Is this correct ? If so, from which version of MAME on can I simply place the CHD's as is into the ROM folder ?
Thank you all
DaredevilDave
  • Last login:August 01, 2024, 03:29:25 pm
  • Yes, I really am still working on it!
Re: MAME CHD Question......
« Reply #1 on: May 11, 2018, 10:10:30 pm »
I don't know for sure. Since nobody else has replied, I believe they still need to be in folders. I'm using 197 and using folders.
I suppose you could just try it?
"Computer Space" (1st coin-op game ever) for MAME Front Ends Available Now!
http://forum.arcadecontrols.com/index.php/topic,155041.0.html
My Custom Motorcycle Cabinet Build For Custom Game (Daredevil Dave):
http://forum.arcadecontrols.com/index.php/topic,151106.0.html
mike boss
« Reply #2 on: May 12, 2018, 02:46:25 pm »
I appreciate the info @ DaredevilDave.
I've moved the CHD's over to the required folder name.
I'll give it a shot this weekend.
