Author Topic: Dual Monitor issue with Groovymame  (Read 5105 times)
Vincefaro
  • Last login:July 17, 2025, 11:40:56 am
« on: February 27, 2017, 02:01:29 pm »
Hi All, Here is my situation. I am have two Monitors one D9800 CRT and one 26 Inch LCD .
I am trying to configure my machine to run dual monitors with Hyperspin using a Windows 7 machine with a ATI 4550
with Groovymame. I am trying to get the D9800 to play Mame only and right now it is playing on both monitors.
Calamity I searched a thread that said that you need a version of GM that is based on Switchres 0.015 at least. From GM main thread:
- LCD marquee support: as a consequence of multi-monitor support, now you can use GroovyMAME with an LCD secondary monitor for marquees. You have to set "use_marquees 1" in mame.ini, use a layout that contains marquee artwork, and these options:
Code: [Select]
groovymame.exe 1942 -numscreens 2 -view1 marquee
You should use -screen0 \\.\DISPLAY#
Replace # by the number of display that represents your CRT. This is because Switchres will only operate on that monitor. This way the LCD will be kept at its native resolution.
Report to moderator     Logged
In my Mame.ini file under
 #OSD Video options I have
numscreen 2
but  I dont know what to change here
# OSD PER-WINDOW VIDEO OPTIONS
screen0                           auto
screen1                           auto
view0                              auto
view1                              marquee
Can you help me out
« Last Edit: February 27, 2017, 07:43:47 pm by Vincefaro »
Calamity
  • Moderator
  • Last login:May 15, 2026, 03:21:10 am
  • Quote me with care
Re: Dual Monitor issue with Groovymame
« Reply #1 on: February 27, 2017, 04:02:41 pm »
Little more to add to the explanation you copied. Replace the # by the correct display number that your system assigns to the target monitor you intend to send the image to. Get those numbers either from a mame log, or from Arcade OSD. You'll see something like \\.\DISPLAY1, \\.\DISPLAY2, etc.
Steps to create a log:
Vincefaro
« Reply #2 on: February 27, 2017, 07:55:45 pm »
Hi Calamity, Thanks for the reply, a couple of questions. Once I do see my system and what it is for display1 and display2 do I then put those in my mame.ini under
screen0                           display1
screen1                           display2
view0                              auto
view1                              marquee
or This?
screen0                              \\.\DISPLAY1
also, under my mame.ini I do have verbose on where do I find that mame.log? Thanks again.
« Last Edit: February 28, 2017, 02:01:23 pm by Vincefaro »
Calamity
  • Moderator
« Reply #3 on: February 28, 2017, 04:25:55 pm »
or This?
This.
(Info to create logs on the main thread.)
Vincefaro
« Reply #4 on: February 28, 2017, 04:32:59 pm »
cool , Do I need to name the the two views as well
view0    ?
view1    marquee
Vincefaro
« Reply #5 on: March 02, 2017, 04:51:29 pm »
Ok, I think everything is fixed. I put numscreens back to one since I only want one screen using switchres my crt! right?
After I got the Monitors to display the proper things Marquee just displaying the marquee artwork, and the CRT just displaying HS and mame when engaged , I then had a problem with my CRT only displaying 640x480 all of my modes were gone, I then re-ran Vmmaker and got my 90 modes back. I then restarted, fired up HS and BOOM I had my modes back beautiful scanlines on my beautiful monitor . Hooray. the last item I have is audio stuttering on most games, I read another post about audio stuttering  and I don't think I have multithreading enabled. I will check to see if it is enabled and hopefully that will solve that issue.
Calamity
  • Moderator
« Reply #6 on: March 03, 2017, 06:10:36 am »
Multithreading is no longer an option in GroovyMAME.
If you set numscreens 1, then GM won't show the marquee on screen1/view1. If you're planning to use HS related software to show the marquee, I warn you it will interact badly with GM.
Vincefaro
« Reply #7 on: March 03, 2017, 05:18:01 pm »
So I should not use Hypermarquee to display the marquee's?
Ilitirit
  • Last login:May 19, 2020, 02:41:58 pm
  • no i'm not
« Reply #8 on: March 08, 2017, 06:12:56 pm »
Should this work with a setup that has two graphics cards?  I have one driving my LCD and another my CRT.  It crashes if I try to use numscreens = 2.  If it's not intended to work like that then it's fine.  If it is, I'll post the logs when I get home.
