Author Topic: cheapest way to paint my arcade  (Read 8012 times)
aqsmorningview
  • Last login:December 27, 2018, 01:47:42 am
« on: February 18, 2017, 07:51:08 pm »
now that i have my arcade finished for the most part,what is the cheapest but still nice looking paint ideas I could use to paint my cabinet? could even spray paint look nice? also after i paint it of course ill decal it a bit
thomas_surles
Re: cheapest way to paint my arcade
« Reply #1 on: February 18, 2017, 08:15:27 pm »
Spray paint may sound cheaper but the amount of cans you need to have a nice finish is actually quite expensive.
  • Last login:May 19, 2026, 11:21:47 am
« Reply #2 on: February 18, 2017, 09:20:21 pm »
Buy good paint and a good roller. Stop being cheap.
« Reply #3 on: February 18, 2017, 09:37:52 pm »
Depending on size, laminate can be cheaper than paint...if you're painting correctly at least.
UEDan
  • Last login:November 10, 2019, 05:54:08 am
« Reply #4 on: February 21, 2017, 05:29:28 pm »
$10 can of oil based paint and a pack or two of $1 disposable rollers.
  • Last login:May 15, 2026, 05:08:29 pm
« Reply #5 on: February 21, 2017, 05:31:40 pm »
You could go the Malenko route and leave the walls unfinished.  Make sure you moan about being broke while you start threads about your latest $1,500 project.
 :lol
morton
  • Last login:July 23, 2021, 09:36:59 am
« Reply #6 on: April 17, 2017, 11:33:01 am »
Is there any good black all in one primer/paint for the insides of cabs?
lilshawn
  • Last login:May 25, 2026, 04:26:29 pm
« Reply #7 on: May 11, 2017, 01:19:05 pm »
1 quart of "Mica Black" colored "paint and primer in one" paint and a foam roller.
shaolindrunkard
  • Last login:February 12, 2026, 11:54:11 am
« Reply #8 on: June 11, 2017, 09:29:13 pm »
Get yourself a can of latex paint in whatever color you want. Paint it on your cab, brush or roller doesn't matter. Do 2 to 3 thick coats. Then once its dry, use a sander and sand the brush marks off. Sand just through the brush marks not through to the wood. Then finish with spray paint in the same or similar color as your base coat. The brush on provides a nice thick base and the spray paint gives you a nice finish coat with no brush marks. Less work than it sounds like.
smass
  • Last login:December 05, 2024, 06:12:33 pm
  • Cheapskate Arcade
« Reply #9 on: June 12, 2017, 09:20:48 am »
Rustoleum Painters Touch 2x Ultra Cover has worked great for me.  Home Depot has it in quart cans with a bunch of different colors - about $8 a can.
« Reply #10 on: June 12, 2017, 12:33:43 pm »
Paint is one of those things that you can't fake and you can't cheap if you want a high end result.  Buy cheap paint, it's easily damaged.  Don't put in the extra work, get mediocre results.  There's just no way around it.
