Author Topic: Taking a TV out of its case  (Read 3501 times)
shmokes
  • Don't tread on me.
    • Jake Moses
« on: January 24, 2004, 06:24:22 pm »
I just took the back off my TV.  I want to make a frame for it and mount it in my cab that way (With the case and speakers off I can make it three to four inches shorter).  Is there anything I should watch out for as far as screwing up the TV?
Also, regarding electrical shock concerns I've taken some pictures and I'm hoping someone can tell me what parts I should avoid touching.
Thanks.
Best Kid iPad Apps
shmokes
    • Jake Moses
Re:Taking a TV out of its case
« Reply #1 on: January 24, 2004, 06:25:00 pm »
Another
Best Kid iPad Apps
shmokes
    • Jake Moses
« Reply #2 on: January 24, 2004, 06:25:30 pm »
3 of 5
« Last Edit: January 24, 2004, 06:27:27 pm by shmokes »
Best Kid iPad Apps
shmokes
    • Jake Moses
« Reply #3 on: January 24, 2004, 06:27:49 pm »
4 of 5
Best Kid iPad Apps
shmokes
    • Jake Moses
« Reply #4 on: January 24, 2004, 06:28:12 pm »
Last one
Best Kid iPad Apps
menace
« Reply #5 on: January 25, 2004, 07:35:39 am »
Avoid touching that large orange'ish wire with the sucker cup--big no-no!  Avoid putting any pressure whatsoever onto the yoke area (the part that juts out of the tube with a circuit board attached) and just don't touch the bare circuit board (although not plugged in its probably safe but those caps can hold residual charges).
If you handle it gently you should have no troubles, and if you do unplug something for whatever reason take some really good digital photos first for reference, you can always delete them later when you're done.
shmokes
    • Jake Moses
« Reply #6 on: January 25, 2004, 07:26:41 pm »
How long does the TV have to be unplugged before it's basically safe to touch anything?
If I just touch the black wire of a multimeter to the frame or something and then touch various places with the red wire should I be able to tell whether anything is hot?
I don't get why they don't run that orange wire through some kind of conduit if it's so bleeding dangerous.  That's just me, though.
Thanks for the help so far.
Best Kid iPad Apps
Nightmare03
  • Last login:August 18, 2007, 07:20:34 am
  • Stupid llama!
« Reply #7 on: January 25, 2004, 09:11:41 pm »
Dude, www.arcadecontrols.com can explain it better than me, has everything you need to know about the tv on there.
delta88
  • Last login:July 14, 2026, 12:34:36 am
  • This place is still here?
« Reply #8 on: January 26, 2004, 12:14:45 am »
http://www.bigjimsarcade.com/virtuaFighter.html
 i just put this zenith from 1992 in my cab... i olny had to unplugthe yoke and degaus coil from the tube.. along with the anode wire..2nd anode that is...  once the tv is off that wire isnt gonna harm ya.. just dont slide your finger under the cap... but it is a good idea to seperate the chassis from the tube when installing.. that way crap isnt messed up or knocked off.. i did knock the convergence tabs good but i pushed em where i thought they were and it looks fine.. huh.. luck? but the only real shock id worry about is if its plugged in and on and your messin on there... but once its unplugged your cool.. only a suprising zap if your not carefull.. nothing thats gonna kill ya unless you have a pcaemaker or sometin' ;)
menace
« Reply #9 on: January 26, 2004, 06:49:00 am »
First question--maybe never, maybe 10 minutes--it depends on the tube and chassis--I've had some that held no charge whatsoever (sanyo tv) and some that held some whopper sparks (wells gardner 4900)  Best bet is to err on the side of caution.
Second Question--probably not a good idea--if you touch part of your meter to an area thats holding a charge it could toast your meter.  If you grab the tv by the tube's edge you'll do fine--I would still recommend separating the chassis from the tube for installation reasons--this also discharges it at the same time so you're golden after that (see the FAQ for instructions if you're unsure how to discharge)
shmokes
    • Jake Moses
« Reply #10 on: January 26, 2004, 08:59:08 pm »
 I don't think I ever would have found arcadecontrols.com had I not seen this post.
Best Kid iPad Apps
menace
« Reply #11 on: January 27, 2004, 07:42:02 am »
LOL--too funny, I find mr. nightmare has the best intentions but is a little too quick with the "post" button ;D
Nightmare03
  • Stupid llama!
« Reply #12 on: January 30, 2004, 11:03:11 pm »
