Author Topic: Opinions/Assistance needed on hardware  (Read 1531 times)
brandon_brummett
  • Last login:January 27, 2017, 05:10:51 pm
  • HELP!
« on: January 10, 2017, 10:55:28 am »
Right before Christmas I stumbled on Todd Moore's article/blog on putting together an arcade system using a 27" TV as the monitor.  Seeing as how I had a 27" tube TV gathering dust, I thought I might try to do something similar.
I got an old computer very cheap on Craigslist; a Dell Dimension E 521 model with a dual core AMD Athlon 64 3200+ 2GHz processor, and 4 GB of RAM running Windows Vista Home SP2 (32 bit).
When I was tinkering around with the system using a LCD monitor hooked to the standard VGA port, MAME and Nestopia appeared to work OK.
I got a Radeon X1300 Pro card to put in there to take advantage of the S-video out capability to hook to the old TV, and the TV appears to work fine as a monitor; but when I try to run MAME I get a message saying that the video card cannot handle the 3D objects.  I have had some success running games like Donkey Kong and Pacman by using the -video gdi tag.
All that being said, I have a few questions
1 - Will the hardware setup described above work, or should I look at trying to get a better PC (especially if it may be cheaper than trying to make upgrades to it)?
2 - Am I better off ditching the X1300 graphics card and getting a VGA converter box for the TV and use with the onboard VGA port on the computer (especially since I didn't get any error messages when running MAME using it)
3 - Or do I have something messed up (which is a distinct possibility)
Any assistance would be greatly appreciated!
« Last Edit: January 10, 2017, 11:08:48 am by brandon_brummett »
brandon_brummett
  • HELP!
Re: Opinions/Assistance needed on hardware
« Reply #1 on: January 10, 2017, 10:08:04 pm »
Tried running Nestopia on the computer and nothing happens.  Thinking the graphics card I put in may be causing a lotime of problems trying to run the emulators...
processedmeat
  • Last login:May 06, 2026, 04:02:04 pm
  • Ikeakade Here I come!
« Reply #2 on: January 12, 2017, 10:55:31 am »
Not sure if this would work but I've noticed that some of my mame builds in the past required DirectX 9.0c drivers.
https://www.microsoft.com/en-us/download/details.aspx?id=34429
brandon_brummett
  • HELP!
« Reply #3 on: January 12, 2017, 11:17:53 am »
I'll try it and see if it works.  I did full deletes and reinstall on the driver (from both Dell and ATI) and that didn't work, so it's worth a shot.
If it doesn't work, I'm ditching the X1300 and old TV and getting an LCD or LED monitor and using the on board port.
