Author Topic: Correct procedure when upgrading GroovyMAME  (Read 1958 times)
CharlieFar
  • Last login:April 02, 2021, 10:56:53 am
« on: December 14, 2016, 12:35:06 pm »
Apologies if instructions for this are posted elsewhere...
Been a while since I installed GM on Windows 7 using a HD4xxx.
Everything works as expected but I want to try the latest build over Christmas.
I also have a slightly better card to install HD5450.
What do I need to uninstall first to make everything go as smoothly as possible?
Will I need to plug my computer back into my LED monitor during reinstallation?
Calamity
  • Moderator
  • Last login:June 16, 2026, 03:08:29 pm
  • Quote me with care
Re: Correct procedure when upgrading GroovyMAME
« Reply #1 on: December 14, 2016, 01:24:33 pm »
Basically uninstall current Emudriver and follow this guide: http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=301
You'll need to use a PC monitor during the process unless you have previously flashed your card using ATOM-15.
Steps to create a log:
CharlieFar
« Reply #2 on: December 14, 2016, 02:17:11 pm »
Thanks for the speedy response.
Sounds simple enough then. Think I'm just being hesitant about messing with the install.
