Author Topic: Nanao MS8 to ArcadeVGA  (Read 2074 times)
shess
  • Last login:January 07, 2021, 04:17:28 pm
« on: November 22, 2016, 09:50:36 am »
I know there are other threads on this topic but my situation is slightly different. I've verified that my monitor is in 15khz mode and works fine with a Sony PS2 and a Jamma board. When I hook it up to my ArcadeVGA though, I get no picture. I've tried the sync wire on both H and V pins but nothing changes. I also hooked the ArcadeVGA up to a WG 25K74XX and it worked fine so I know the card is good. I was thinking I need a video amp, but I thought I should at least see a dim picture without it.  Anything else to try first?
grantspain
Re: Nanao MS8 to ArcadeVGA
« Reply #1 on: November 23, 2016, 12:57:16 am »
is it ok with a standard jamma board
shess
« Reply #2 on: November 23, 2016, 08:35:14 am »
Yes, I tried it with my CPS2 setup and it worked fine.
danielm7999
  • Last login:January 11, 2017, 02:01:48 pm
    • Daniel Mercer Art
« Reply #3 on: November 23, 2016, 11:40:40 am »
Have you tried contacting Andy at Ultimarc? He usually has a few things that he'll ask you to rule out for starters. He probably won't get very in depth on it though, but he's good help at times. Also there are quite a few steps for properly setting up ArcadeVGA...I assume you set all of that up properly, otherwise it wouldnt have worked on your WG. I'd hit Andy up for starters and let him know you had it working properly on your WG, so youre apparently doing all of the setup correctly. He might know more about using it with a Nanao MS8. First thing hes gonna ask you is if you can see the Galaga icon on your lower right screen with all the different resolutions. Again, I'm pretty sure you already have that. Good luck man!
- Daniel Mercer Art
grantspain
« Reply #4 on: November 23, 2016, 12:43:52 pm »
ms8 are really picky with sync signals,i have also known mame setups to damage the custom sync module on these
shess
« Reply #5 on: November 25, 2016, 10:57:56 pm »
After talking to Andy, it turns out the brightness on the monitor was just low enough that I couldn't see the picture. After turning it up all the way I saw the boot up screen. Presumably a video amp will fix this issue. Thanks for everyone's advice.
danielm7999
    • Daniel Mercer Art
« Reply #6 on: November 25, 2016, 11:36:29 pm »
Great! Glad Andy was able to help you out
- Daniel Mercer Art
