Author Topic: LEDBlinky and ServoStik problem  (Read 3071 times)
LeedsFan
« on: November 16, 2016, 06:39:25 pm »
Just got my ServoStik installed but can't get it to switch automatically for games.  ServoStik does switch using the JoyTray program. But in Hyperspin it just sits there.
I did follow these instructions on this webpage:  http://www.projecthive.ca/?p=173  Got all the file paths to control.ini and mame.xml setup and the same boxes ticked/selected as per these instructions.
But I didn't follow the instructions for the LEDBlinkyControlsEditor.exe just yet     That seems like a hell of a lot of work selecting each game individually like that. I thought the idea was to read the Mame.xml or the controls.ini file on game launch to select 4-way or 8-way?
I also am using the trial version of LEDBlinky. Wanted to make sure it was all working before buying the code for no-nag. Then I was thinking maybe ServoStik support isn't in the trial version?  Anyone know?
I did consider using hardware mode for now and then try this out later. But it seems that's a one way street if I do that as hardware mode is irreversible.  :dunno
LeedsFan
Re: LEDBlinky and ServoStik problem
« Reply #1 on: November 17, 2016, 03:17:43 am »
OK I've dug around a bit more.  In the LBC_Errors log I am getting "BASS_RecordInit failed. Error: BASS_ERROR_DEVICE (23)"
Anyone know what this is please?
arzoo
  • Last login:July 05, 2026, 11:11:48 pm
  • Robots WILL kill you.
    • LEDBlinky
« Reply #2 on: November 17, 2016, 02:12:11 pm »
You are correct, no need to add mame games individually - that's what controls.ini and mame.xml are for. The controls editor is mostly for non-mame emus. As for the BASS error, LEDBlinky is unable to detect your audio card. But if you're not using audio animations then you can ignore the error. I responded to your post on the LEDBlinky thread :)
Robots will kill you.
Arcade Addiction
